HP 15-g092sa / LA-A996p dead
  • artois7
    • Mar 2011
    • 159
    Been a while since I've looked at a broken laptop.
    Got a HP 15-g092SA (LA-A996P mobo with AMD A8 CPU) here for a family friend, no signs of life / no power.
    No short across the DC jack, but only reading ~~0.7v plugged in so something is shorted.
    Can't find a schematic or obvious reference points on the board. Any experience with these? Surface mount CPU, might hit it with some heat and see if reflowing makes a difference.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: HP 15-g092sa / LA-A996p dead
    Don't mess with the CPU until you've ruled out everything else.
    Especially here, if you think that something is shorted in the B+ line, you must find the shorted component, reflowing the CPU won't magically relieve the short.
    First make sure that it's not a continuity problem like a broken DCIN jack. (or connector on the motherboard)
    Second, check if the actual short is on the VIN or B+ line.
    If you don't see any obviously burnt or bad looking component, you'll have to inject a voltage with a PSU to the shorted line (start with 1V) and find the component which is heating up.
    Schematics attached, was pretty easy to find on Google…
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      This mobo is notorious for 3v regulator fail. So check it first.
      • OOF DIO
        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
        by OOF DIO
        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
        (Had 3 problems, now just 1)
        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
        04-19-2025, 05:03 PM
      • BalkanBoy
        Dead Razer Blade 14 2022, shorted CPU?
        by BalkanBoy
        today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
        Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
        I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
        Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
        I removed coil and injected 0.7V, it draw around...
        09-27-2024, 12:44 PM
      • FeerBaron
        PNY XLR8 RTX 3090 dead. Is this PEX shorted? Am I cooked?
        by FeerBaron
        I rebooted my computer and suddenly it didn't detect. It was nvlinked to another card that works. Lights don't light up. I checked around with DMM from youtube videos but didn't find a really good diagram except the one from 3090 FE. Going by that it looks like this is PEX? In that case the last option is to lift the coil and see which side is shorted or GPU is gone?
        This card started out used with a bad HDMI port and worked for about a year. Guess it doesn't work anymore. I was going to send it to a repair service in case of mosfet or some tiny IC they can air station swap. If the...
        01-31-2025, 12:13 PM
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • pc_okay
        G703GXR Dead CPU? shorted CPU power mofset replace, missing DRAMRST#
        by pc_okay
        Hello friends,
        I replace a shorted mofset (PU8104), now laptop is starting but no display, stopping at DRAMRST#.
        Resistance to ground on PL8104 is around 1-2 ohm, quite low but voltage seems ok 0.995V
        Any help would be appreciated it's a nice laptop !
        Thanks. 😃
        04-02-2025, 04:48 AM
