Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
This topic has been answered.
  • mkdj
    • Mar 2025
    • 49
    • France
    Dear all,
    Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
    I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
    I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the CPU.
    This is my first short circuit detection on a motherboard. Any advice on what I should do now?
    Regards,
    mkdj
  • Answer selected by mkdj at 08-22-2025, 08:45 AM.
    mkdj
    • Mar 2025
    • 49
    • France
    Dear all,
    Because only the CPU is heating when injecting voltage on the 3.3V power rail, I conclude that the CPU is dead, and that the board is not fixable.
    Thank you mon2 for your help.
    Regards,
    mkdj
    • mon2
      • 14725
      Most likely the defect is with the PCH (CPU) that uses the same rail.
      • mkdj
        • Mar 2025
        • 49
        • France
        Thank you mon2 for your comment.
        Does that mean that the CPU is dead, and the board can't be fixed without replacing the CPU?
        What if I reflow or (try to) reball the CPU, could that solve the issue?
        Regards,
        mkdj
        • mkdj
          • Mar 2025
          • 49
          • France
          Dear all,
          Regards,
          mkdj
          • mkdj
            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
            by mkdj
            Dear all,
            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
            Both N-Channel Mosfets: nothing odd
            P-Channel MOSFET number 1:
            source - drain : 117 kOhm
            source - gate: 96 Ohm
            gate - drain: 117 kOhm
            P-Channel MOSFET...
            08-20-2025, 06:08 AM
          • barry101
            Apple 820-3662 VCore shorted to ground.
            by barry101
            Hi, Would appreciate some help.
            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
            Get charger light but no fan spin or chime. No liquid damage.
            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
            06-24-2025, 07:34 AM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • AppleLover123
            Acer Nitro 5 comes on then goes off
            by AppleLover123
            Hey guys,
            i've got this laptop from a friend who gave it to me in a dead state.
            The laptop wasn't working at all so i've began my search on the 19V power rail.
            It was shorted to ground so i injected voltage and the only thing getting hot was my ground clip from my power supply.
            I found that the +1.05V Rail for the Chipset was shorted. i removed the coil and it was shorted on the power delivery side.
            The pch seems fine bc the rail has over 50 ohms after i removed the coil.
            Still nothing was getting hot so i suggested the chip must...
            10-09-2025, 04:51 PM
          • L.L.
            EXO UX133 the KBC has pin shorted to ground
            by L.L.
            Hi, on the UX133U motherboard (little info) the KBC (IT8987) has pin 59 shorted to ground, so there is a key always pressed.
            Does anyone know if it can be cancelled by modifying the bios bin or reprogramming the KBC?
            Thanks.​
            03-05-2025, 10:46 AM
