Compaq with power issue
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    Please i have this Compaq presario CQ60,when my costumer brought it a caps was burnt on the board and after clearning and changing the spoilt capasitor i notice U47 ic was warming,i changed it and i have power on the board now but when i press the switch the laptop doesn't on,i made another check on the board and notices any ic on the board warms again,please can any one help me with the diagram of the board
    Astrosphere MCP MB
    07241-5
    48.4J103.051
    That is the board number,tnx in advance
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Compaq with power issue
    Should be this one.
    • emmanuelbill1988
      • Mar 2017
      • 100
      • ghana
      Please which page do you think i should check?
      • emmanuelbill1988
        • Mar 2017
        • 100
        • ghana
        Please mine is CQ60,any one
        • piernov
          • Jan 2016
          • 4439
          • France
          MB is Wistron Astrosphere, should be ok. Check if 3.3V/5V is present and if you have 3.3V on power button. Check if PM_RSMRST#, PWRBTN#_MCP and PM_SLP_S5# gets high after pressing power button.
          • emmanuelbill1988
            • Mar 2017
            • 100
            • ghana
            After making the checks am not getting 3.3v under switch and U56 becomes hot when i put in the charger but power jack Led shows on,please what maybe the cause of U56 becoming hot?tnx
            • mielta
              • Apr 2015
              • 368
              Hi
              Messure Pin8,16,17 from icU56
              • emmanuelbill1988
                • Mar 2017
                • 100
                • ghana
                After measuring with charger plugged in i had
                Pin8-3.2v
                pin16-4.9v
                Pin17-0v
                • mielta
                  • Apr 2015
                  • 368
                  messure Pin17 because a short to ground
                  also can U56 be defect
                  • emmanuelbill1988
                    • Mar 2017
                    • 100
                    • ghana
                    After taking measure again i got
                    Pin8/3.2v
                    Pin16/18.9v
                    Pin17/4.9v
                    Thats when i plug in the charger,is U56 defeat?
                    • wisnak
                      • Apr 2018
                      • sweden
                      I have the same motherboard CQ60 and the power jack led is on when i pluck the adapter and led 1 is on when i press the power button no led 3 and there no firther action and the the U48 start to be warm as usual and cpu fan not spinning, where i will start searching? any one has the boardview cause i cant finde som component like U47 or U56..?
                      than you in advance
                      • Soulzink
                        Samsug washing machine. Power supply DC41-00189a board issue
                        by Soulzink
                        I am trying to fix a samsung washinmachine power supply main board.
                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                        The power supply board reference is the following: DC41-00189a
                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                        04-19-2025, 06:26 AM
                      • Asraf Atb
                        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                        by Asraf Atb
                        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                        01-27-2025, 05:02 PM
                      • Stephen
                        A2991 Logic Board issue, 20volts 0 amps help!
                        by Stephen
                        Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                        09-10-2025, 03:16 PM
                      • Stephen
                        A2991 logic board issue, 20volts 0 amps help!
                        by Stephen
                        09-10-2025, 03:15 PM
                      • notallbad
                        TCL 55RP620K power board issue
                        by notallbad
                        Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                        0% p_dim at 1.65v and a_dim at 1v
                        50% p_dim at 3.3v and a_dim at 1.65v
                        100% p_dim at 3.3v and a_dim at 2.88v
                        Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                        Leds are 2 rows of 15 6v leds.
                        On inspection of the power board found diode MBR3200 shorted so replaced with...
                        07-12-2025, 05:45 AM
