How can I convert hp g62 discrete to uma
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    motherboard part number : da0ax1mb6f0
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    Re: How can I convert hp g62 discrete to uma
    The question is why would you do it? this does not make any sense to me.
    • razu
      • Jan 2015
      • 218
      • Bangladesh
      I do it for simple display problem repair, without Change chips.........@sopik78
      Do you understand this
      • sopik78
        • Nov 2013
        • 519
        • Czech Republic
        If you have simple problem, do it simple way. And it is definitely not to convert dis to uma on this board.
        Just get the schematic and compare the differencies between uma and dis version, it means to change a lot of parts and flash SPI to uma BIOS.
        Or get some uma board and match it with your dis.
        After this you choose other way for sure.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          ax1 is very difficult to convert, need to add and remove a lot of components.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Not that difficult man, have converted atleast 5-6 such boards succesfully. It makes sense to convert from dis to uma as ati chip fails on this mobo.
            If you need i can post the knowhow to convert.
            No need to flash bios after conversion.
            • String2016
              • Nov 2015
              • 2238
              • philippines
              can you please upload the tutorial for conversion please
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Here is the conversion details+Boardview(without which its very difficult to locate components
                Enjoy
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  thanks for sharing
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    If need arises, I can post my converted mb pic. You try it out first.
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      if it is ok can you post your converted mb please
                      • razu
                        • Jan 2015
                        • 218
                        • Bangladesh
                        Thank a Lot of all bad caps friends.......
                        • razu
                          • Jan 2015
                          • 218
                          • Bangladesh
                          Board viewer software for all Download and enjoy
                          • minhajcool
                            • Feb 2017
                            • 13
                            • india
                            thanks sir
                            • sourcebf
                              • Jul 2016
                              • 433
                              • N/A
                              Enjoy
                              thanks for sharing
                              • fyaagoub
                                • 269
                                • maroc
                                thanks sir for sharing
                                • dreamer_x_x
                                  Ottoman Empire
                                  • Nov 2016
                                  • 18
                                  • turkey
                                  hi bro. is it working ?
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Yes, its working 100% provided you understand and do it right.
                                    • dreamer_x_x
                                      Ottoman Empire
                                      • Nov 2016
                                      • 18
                                      • turkey
                                      Hi , very thanks bro.i will try.
                                      • memoslar
                                        • Apr 2015
                                        • 122
                                        • Greece
                                        Hi, i have DAAX1JMB8C0 with the processor on board. Will it work? I tried except the seventh picture. But its not powers up.
                                        In 7th stage cant figure out the position of the capacitors.
                                        I have one difference in picture 2. I had 75 ohm resistors instead of 70 ohm in r497 , r498, r499
