Replacing ribbon cable...(not that simple, hear me out)
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    I have this Asus G73JH and after a lot of work replacing the video card, I was putting it back together and before I put it totally back together I booted windows. In win10 the touchpad worked for a few seconds then stopped. I didn't understand why so I looked at the ribbon cable and the contacts were all falling off and some shorted across (though I didn't smell anything burning)
    I tried to straighten them out the best I could and put it back but they were too loose. Instead of getting the cable for the model laptop from ebay for an exorbitant amount, I got one from Mouser that had the same # of contacts, pitch (0.5) and length (though I never got a spec on voltage (60, 30) or awg)
    when I put it back on, the power light didn't come on, the HDD light did, and I started to smell something burning so I disconnected the power real quick (the cable is hooked to the LED board which has another cable to the touchpad)
    what am I missing here? did the old cable short out something that now hooked back up is frying?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Replacing ribbon cable...(not that simple, hear me out)
    is it possible I burned the microcontroller out?
    hm, now that I look at a disassembly guide, I think the cable has the contacts on opposite sides, does that mean the connection is reversed?
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Yes , it was reversed . It was better if you kept the original one , cut an appropriate piece of plastic to fit the loosing size .
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I know what you're talking about, but two of the contacts were totally off, so I could not shorten it to a size where they were still intact
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Yes , sometimes it get very nasty . Using a sharp scissor to ameliorate a tough situation may fail too .
          Remain to say that i saw many laptos not powering at all if the pad's microcontroller is damaged ..
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            got the reversed FFC today (love living 5 minutes from mouser HQ and picking up from will call). Whatever got hot enough to smell didn't burn, the touchpad and LEDs (what is also on that touchpad board) works too (at least the power and HDD led does). Can't test the battery and 4th whatever it is I forget till I get it together enough
            and of course I just saw the FFC going to a button board on the side with torn contacts, but I think I can cut it (I have a pair of VERY sharp scissors)
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              good work for fixing
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                UGH Pointless in the end. This laptop is f'd. Started rebooting, freezing, used chkdsk, let it run, now there is a permenant orange line in the screen. I checked the connectors. The screen is new, the MXM video card was replaced and is used from china. I'm guessing it was reflowed and even though I arctic silvered it, it must have been poorly flowed. I give up. This thing at once time was filled with hundreds of german cockroaches, twice. I'm surprised it lasted as long as it did
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  only one line on lcd could be bad flat cable or bad lcd.
                  if pc freezing or elase could be bad pch or bad videocard or could also be other problem.
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    An external monitor would affirm if it's the LCD damaged . Freezing and restarting can be a defective Ram so clean and re-seat them .
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      the LVDS cable was good, I replaced the screen and it was just fine when I hooked it up, even before I fried the old screen by using a different LVDS cable (checking if the cable was the issue)
                      the original LVDS cable never gave me any issues till I left it alone for the checkdisk (never moved it). I'll hook it to the HDMI port later today. worst case scenario, bad MXM (again), next to that, bad screen. But so much money has been put into this old thing.
                      windows did boot fully several times, but it started having problems staying on for extended periods of time. This reeks heat issues
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        if pc freeze, or reboot itself, to exlude a bad mxm video card, just uninstall ati or nvidia video card driver and use generic vga driver instead and disable installing driver fror vga via windows update. if pc stays on fine and u can do everything and pc still work fine, then its a vga problem. if pc freeze with generic video driver then could be bad ram, bad cpu, bad mosfet at power circuit or bad pch or something else.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          I can't get to the point where I can uninstall the driver. it boots to black with touchpad even with safemode
                          hdmi doesn't have the line. the LVDS cable was never moved during the checkdisk, so i'm guessing its the new screen. The cable never indicated any problems since the new screen
                          I moved ram in and out with the same results. So possible motherboard, power issues. I've already spent most of the $360 I was given to fix this thing on parts themselves. I just told the guy i'm giving up on this ~8 year old gaming laptop because who knows if the (used) motherboard for ~$170 might last. Its not worth it as this point. Thanks for the ideas and help everybody but this has been one small issue rolling into another from the beginning.
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            Maybe the LVDS is good , and the screen is good too , but , it's not compatible . There are lot of different specs for a compatible LCD other than the usual inches , it happened many times with me , HD , TL1 , TL2 , TL3 , WXGA , etc . That , in my opinion explain well the single line ..
                            I checked this laptop specs , and if it's Icore 7 , then it is still worth ...
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
                            • joblo37pam
                              Sharp LC-80LE844U Blinks 2 slow, 5 fast
                              by joblo37pam
                              It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                              The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                              10-26-2023, 02:17 PM
                            • AK_777
                              Sony KD-65A1 Repair – 4 Red Blinks Error
                              by AK_777
                              Hi everyone!
                              I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                              Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                              02-20-2025, 04:15 PM
                            • Rubenlily
                              Quick question about the ribbon
                              by Rubenlily
                              Hey,
                              So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
                              When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
                              08-17-2023, 11:09 AM
                            • harp
                              simple win network with optimization issue
                              by harp
                              simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                              06-23-2025, 11:01 AM
