Lenovo G50-80 Missing component
  • tsiga
    • Jan 2014
    • 76
    • ott
    Hi!
    I have lenovo g50-80 (ACLU3/ACLU4 UMA NM-A362). The mootherboard is water damaged. One little component is missing.
    when i plug dc, the machine turn on automatically but no boot logo or anything.
    Can anyone identify this component?
    Any advice would be much appreciated Thanks!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo G50-80 Missing component
    Do you expect someone to respond without attaching the photos???
    • tsiga
      • Jan 2014
      • 76
      • ott
      LOL sry. In turn i attached.
      Picture 1
      Picture 2
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        No component in place on those pads. One pad totally corroded , see if it's connected with other pad and replace connection.
        • khaahk
          • Dec 2013
          • 756
          • Estonia
          From another picture shows resistor, value unknown.
          • R_J
            • 9535
            I found a schematic for a NM-A272, on page 46 it shows Q25 with one end of R149 (150K) connected between +20vsb and D of Q25
            Panjit semi shows the 2n7002KW with a marking K72 so it looks like the same fet
            • tsiga
              • Jan 2014
              • 76
              • ott
              #jasko_jacker#
              Yes, the pad fully corroded. there was a resistor but can't measure.
              #khaahk#
              Thank you!
              #R_J#
              Thank you, I watched this schematic before write post. These two motherboard is different.
              I measured Q25 (Q27 in schematic) drain leg this pin connect to Q24(3VS) gate leg.
              If my assumption is wrong, there will be more damage in MB.
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                Try with small hight value potentiometer.
                • lovendhra
                  • Dec 2020
                  • 5
                  • South Africa
                  Hey Tsiga whatever happened to that water damaged laptop i think mine has a similar problem. as soon as you plug in power connector it comes on. and nothing on the screen its blank.. i have similar corrosion around q25 area..
                  • emestee
                    • Dec 2019
                    • 228
                    • Bulgaria
                    The first place to start diagnosing self-start problems is the power button and whether the corresponding EC pin is shorted to ground...
                    • TecnicaNTT
                      Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                      by TecnicaNTT
                      I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                      My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                      I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                      I am now asking here for help if anyone knows how to do this in...
                      09-20-2024, 08:10 AM
                    • m0jo1103
                      Need help.... Lenovo L340-15IRH mosfet missing!
                      by m0jo1103
                      Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
                      05-19-2025, 07:13 AM
                    • mat2k
                      Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                      by mat2k
                      Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                      BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                      I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                      12-01-2024, 11:00 PM
                    • G_sene
                      Lenovo G40-80 ACLU3 ACLU4 NM A362 not charging
                      by G_sene
                      Hi, everyone.
                      I have this notebook that won't charge.
                      In Windows, the charger icon doesn't appear on the battery, but the charger turns on the notebook normally.
                      PU301:
                      Pin 5 (ACOK) - 5.97v
                      Pin 6 (ACDET) - 1.83v (should have 2.6)
                      Pin 16 (REGN) - 6v
                      PQ308 has no gate voltage, so it doesn't drive PQ309 low
                      With the battery connected, its voltage goes the reverse way to the jack, having 14v and not 20v:
                      PQ301 e PQ302
                      Pinos 1,2,3 14v
                      Pino 4 5v
                      Pinos 5,6,7,8 com 14v...
                      06-24-2025, 11:22 AM
                      Lenovo 3000 Series Schematic
                      Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                      3000 C100 laptop with Braille keyboard
                      Lenovo 3000 C
                      C100, C200 - 15-inch XGA screen
                      Lenovo 3000 N
                      N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                      N500 - 15.4 inch screen.
                      Lenovo 3000 V
                      V100, V200 - 12.1-inch WXGA models
                      Lenovo 3000 G
                      G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                      10-04-2024, 06:05 AM
