dell laptop with power problem
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    please I urgently need help with this dell laptop,when you put the charger in the power jack the charger light goes off ,on dell laptop mostly it's a bad caps which normally does that,after checking all caps on the board whether some is burnt ,it all looks OK,please can anyone help me with what to check next?motherboard number is LA-9104P Rev:1.0(A00)tnx in advance
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: dell laptop with power problem
    Dell inspiron 3521 (la-9104p):
    • emmanuelbill1988
      • Mar 2017
      • 100
      • ghana
      please which page
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Originally posted by emmanuelbill1988
        please which page
        A good start is to check and compare voltages from page 35 .
        P.S. Dell adapters sometimes show the same problems when loading . Try another adapter .
        • piernov
          • Jan 2016
          • 4435
          • France
          Probably a short to ground on B+ line. Check resistance to ground of a component on that line (PR102 for example).
          • emmanuelbill1988
            • Mar 2017
            • 100
            • ghana
            I just removed PR102 and when i connect the power the charger light does not go off,does it mean i should replace PR102,please?
            • piernov
              • Jan 2016
              • 4435
              • France
              No, I told you to mesure resistance between PR102 and ground. You have a short to ground on the B+ line.
              • emmanuelbill1988
                • Mar 2017
                • 100
                • ghana
                OK will check now
                • mielta
                  • Apr 2015
                  • 368
                  Hi
                  You must search in the schematic after B+ you will find many jumper interrupt them
                  and messurs on whitch side is the short to ground
                  • emmanuelbill1988
                    • Mar 2017
                    • 100
                    • ghana
                    OK I will try and do that
                    • sagrmale
                      • Aug 2018
                      Hi Emmanuelbill did you solved your problem, what was it exactly?
                      • PacoGT
                        HELP!! Dell E6440 laptop with problem does not turn off and turn itself on help
                        by PacoGT
                        A few days ago my laptop gave me problems, when I wanted to turn it on to my surprise without charging so I did not put much importance on it, after that I turned it on with a charger, it turned on and charged the laptop, the problem with the laptop is that when it is turned off it turns to turn on after seconds, sometimes at 2 or sometimes at 8, other than that it works normally, I already checked many things, I changed a mosfet at the charge input to a pnp but it remained the same, after that I checked and I did not find anything outside Normally, before that, it had a failure where I changed...
                        07-11-2023, 09:31 PM
                      • bhamra
                        Dell G3 3579 LA-F611P Laptop not charging problem
                        by bhamra
                        I got one Dell G3 3579 Laptop not charging problem. laptops turns on shows charging sign but actually not charging.
                        works fine on battery as well.
                        Any Solutions?
                        Thanks in Advance...
                        12-23-2024, 04:33 PM
                      • ahmarzo
                        Acer TMX314-51 laptop battery problem
                        by ahmarzo
                        I have acer laptop tmx314-51 with part no 6050A3020501.
                        The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                        But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                        I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                        The schematic is not available...
                        04-11-2025, 09:14 AM
                      • mikey5791
                        Dell laptop model PP24L won't start from ac adapter
                        by mikey5791
                        Dear all,
                        Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                        But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                        03-24-2023, 09:06 PM
                      • Mots06
                        Old Dell E5400 Laptop ( Purchased in the year 2008)
                        by Mots06
                        Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                        07-19-2025, 01:56 AM
