Dell G3 3579 LA-F611P Laptop not charging problem
  • bhamra
    • Mar 2024
    • 13
    • New Zealand
    I got one Dell G3 3579 Laptop not charging problem. laptops turns on shows charging sign but actually not charging.
    works fine on battery as well.
    Any Solutions?
    Thanks in Advance
  • mon2
    • 14189
    Could the battery be old? If available, suggest to simply replace the battery and test again.
    https://www.badcaps.net/forum/troubl...arging-circuit
    Start with the above article. Share more details of your laptop with full markings on the logic board. Ideally, link the schematic if one is available but only inside the dedicated schematic forum.
    Plan B is to try to convince piernov to do an onsite repair. We have been trying for years...
    Plan C is to continue this thread for more assistance. You will need a multimeter; soldering tools if parts need to be replaced; tweezers; flux; solder and patience.
    Be sure that your power adapter is suitable for charging. Any liquid damage? What is the history of the unit?
    • bhamra
      • Mar 2024
      • 13
      • New Zealand
      Battery Seems fine as it is working on battery as well.
      gone through schematic but couldn't diagnose the problem.
      changed adapter as well. no liquid damage on motherbaord.
      • mon2
        • 14189
        Remove all power. Meter in resistance mode. Measure the resistance from pin #1 to pin #2 on the charger IC at pub01. Measure directly at the charger ic pins.
        What is the resistance in ohms?
        Next, touch your meter probes together and share this 0 ohm measurement. This is your baseline of the lowest measurement of your meter. Need this value to gauge the others.
        • bhamra
          • Mar 2024
          • 13
          • New Zealand
          It is 2.4
          • mon2
            • 14189
            Not understanding the posted values. Can you share a pic of the front face of your meter? Be sure that you are in resistance (ohms; omega Greek symbol) mode on the dial.
            Then touch one meter probe onto pin #1; other probe on pin #2 - the meter will report the resistance measurement for the path between these 2 points of initial interest. The measurement will be in ohms.
            • bhamra
              • Mar 2024
              • 13
              • New Zealand
              It is 2.4
              • mon2
                • 14189
                This resistance is ok and is the battery charger current sense resistor path.
                Can you confirm the details of your power adapter? Is it the USB type C or standard barrel style power adapter? Regardless, they are of the Dell brand or another?
                Are you able to power with only the power adapter? (no battery)
                • bhamra
                  • Mar 2024
                  • 13
                  • New Zealand
                  It is Original standard barrel style power adapter. i have checked with another adapter as well.
                  I can power on with power adapter ( No Battery) and also only with battery.
                  Just the battery doesn't charge.
                  • mon2
                    • 14189
                    When you use the barrel style power adapter - what power rating of this adapter does the BIOS show?
                    About to take in my nightly Netflix binge watching but after the above check...test the voltage to ground of the PSID pin on the barrel jack connector @ PL3 ferrite bead.
                    Dell uses the 1-wire communication spec by Dallas Semiconductor / Maxim / Analog (in this order of who owns whom) - and this PSID line is used by the EC to determine the power rating of the Dell official power adapter. You cannot sub another unless it is 100% compatible with Dell.
                    If this line is missing, the power adapter will be assumed to be wimpy and the charging feature will fail and most likely will throttle the speed of your CPU. The BIOS will confirm what the adapter is or is not.
                    • bhamra
                      • Mar 2024
                      • 13
                      • New Zealand
                      it is being Detected as original 180W charger in bios. i have replaced the charger as well but same issue with another charger as well.
                      Getting 19.5 volt.
                      • mon2
                        • 14189
                        Is the battery the original and proper model for this laptop?
                        • Robocop
                          Dell G3 3579 (LA-F611P) not charging
                          by Robocop
                          Hey guys,
                          I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
                          In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases)....
                          06-25-2024, 08:15 PM
                          DELL G3 3579 Notebook Specification for Upgrade or Repair
                          This specification for the DELL G3 3579 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3579 boardview and 3579 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL G3 3579 Notebook is...
                          09-06-2024, 09:23 AM
                        • Scoff
                          HP Probook 470 G4 - Power and Charging Problem
                          by Scoff
                          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                          07-03-2023, 09:28 AM
                        • toti24
                          (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                          by toti24
                          dell precision m4600 laptop
                          i7 2760qm
                          8gb ram 750gb HDD
                          intel hd 3000 integraded and nvidia quadro 2000m
                          pleasea bear with me english isnt my language and ill try to be as clear as possible
                          note i live in mexico in a very small town..
                          thank you.
                          laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                          the brick happened when i was installing win 10 using usb.
                          used rufus and officia microsoft.iso
                          it finished copying files from usb...
                          03-06-2022, 08:39 PM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
