What is this pink Stuff?
  • DanFen
    • Apr 2017
    • 201
    • Malta
    I have this Lenovo laptop that power on but no display. I checked the basic stuff (like screen etc...). When I disassembled the laptop, I noticed the following (I've never seen on any other boards).
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: What is this pink Stuff?
    Seems to be a thermal pad
    • DanFen
      • Apr 2017
      • 201
      • Malta
      Checked some original pictures of this motherboard and there seems to have been some kind of connector before. The pink stuff is also on the other side of the motherboard, so it seems that it was "drilled" from one side to another.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        it is not genuie. i think some kind of fingernail to isolate ripped board
        • DanFen
          • Apr 2017
          • 201
          • Malta
          Maybe it was repaired before, or else maybe they bought it refurbished without knowing :o
            Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
            This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
            09-06-2024, 09:30 PM
          • jimjoe123
            LCD TV Green/Pink screen problem
            by jimjoe123
            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
            Then each time...
            02-23-2020, 01:29 AM
          • AstutePauciloquent
            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
            by AstutePauciloquent
            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
            11-23-2023, 11:02 PM
          • vpower
            dead HP Pavilion Laptop - 16-a0021nl
            by vpower
            I have this dead laptop, if I plug the charger I see only charging led light blinking 3 times.
            I disassembled it, removed the battery and checked with my multimeter:
            red arrow input connector 19v
            green arrow first mosfet drain 19v
            white arrow first mosfet source 3v
            yellow arrow second mosfet 19v
            pink arrow 3v
            blue arrow third mosfet shorted to ground
            current resistor 3 volts on both sides
            Any advice? I have a thermal camera and I could inject low voltage if needed.
            Thanks...
            04-24-2024, 01:24 AM
          • YellowJacket
            Asus VX238H - pink area over picture
            by YellowJacket
            Hi friends,
            I got this monitor, which works perfectly fine, except there is pink discoloration over right side of the screen ( picture1 ). When I disconnect LVDS cable, there is no sign of pink color, so its not backlight issue ( picture2 ). I took a closer picture of the upper right corner, you can see even some kind of pixel defects. Its only on that pink area ( picture3 ).
            I believe, there is some problem inside the panel, the question is, if it is fixable. I have never met this kind of issue, so I really appreciate little help from you guys. What I tried so far - interrupt...
            08-17-2023, 11:45 PM
