Help wanted with 2009 macbook pro no power
  • izzzzzz6
    • Jul 2014
    • 24
    • France
    Hi Guys. Hopefully i got this right and my post is in the correct place. I suck at forums. It took me an age to find where to post this question
    I was just about to sell my old macbook pro when it died on me. I can't find the boardview for this machine but i found a similar one. Board is 820-2565-A
    Battery seems to be charging ok and indicator lights seem to be working. No fans nothing, everything else seems lifeless.
    I found a blown white fuse near to the display connector. On the other similar boardview i have this appears as a diode D9701 is the closest thing i could find to the white fuse i have. Seems to be linked to the backlight but i have no boot up let alone backlight issues.
    Causes might have been, old battery pulling constant current or perhaps some metalic crap i found magnetically stuck to the magsafe port.
    I didn't check all voltages as i am not really sure where to test but i saw what might be V in 12. something volts near to U7200 but not much else going on around here.
    I also found 3. or 4. something volts (can't remember now) on a 3 legged component by the top edge near the display connector and near to my white fuse.
    I don't want to keep comparing to components in the board view i have as it is not exactly the same.
    The blown fuse is baffling me as i don't know what it does or where it go's. I am assuming it has something to do with the backlight connector but why would it blow and also the board not be booting up?
    One side of the fuse measures short to ground, this seems a bit strange to me but perhaps it's supposed to be like that?
    I didn't want to bridge it as
    A. I don't know it's value (is it the 6A fuse?)
    B. I don't want to blow anything else, if something after the fuse is shorting to ground then the fuse will simply blow again.
    Mission is to find out more about this fuse and find out if some other component has shorted.
    Has anyone seen a similar problem with the 2009 or perhaps the 2010 Macbooks?
    EDIT: I have just attached an image i found online. Please ignore the missing component outlined and look for the white fuse on the top right.
    Thanks.
    James
    Last edited by izzzzzz6; 03-22-2017, 07:45 AM. Reason: adding image and explination
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Help wanted with 2009 macbook pro no power
    Use this
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      c'est sur que tu sauras maintenant si t'as réellement affaire à un fusible un condensateur non polarisé ou ......
      • RobertJB66
        • Nov 2017
        • Netherlands
        Hi Guys, i'm working on an 820-2565-A board.
        I have done a number of measurments and it looks like the power is gone rather quick.
        I have checked the variouse powers related to the PBus Supply & Battery Charger (page 64 of the diagrams.) (see attached my results.
        PPDCIN_G3H = 17.1 V
        PPDCIN_G3H_INRUSH_FET =17.1 V
        PPDCIN_G3H_INRUSH = 16.8 V
        PPDCIN_G3H_CHGR = 16.7 V
        PP5V1_CHGR_VDDP = 5.1 V
        PP3V42_G3H = 0 V
        PPVBAT_G3H_CHGR_REG = 0V
        PPVBAT_G3H_CONN = 0V
        Fan is connected to the board, no battery only the Mac Safe, no green light.
        Does one of you a sugestion what to do?
        thanks
        • socketa
          Bestec ATX0300F5WA - fast,or slow blow, fuse?
          by socketa
          I bought a dead motherboard, and connected it to this PSU,
          Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
          So now i truly got a bang for my bucks, and something else to try and fix.
          The fuse was blowen, and the top was blowen off of a TNY276PN chip
          The glass fuse didn't have any marking to say if it was fast or slow blow
          So i checked the marking on the PCB thinking that that would tell me,
          but it 's got a T/F8A printed on the board
          So should i get a fast blow fuse, or should...
          05-17-2022, 01:22 AM
        • envym
          MacBook Pro 2018 with Activation Lock
          by envym
          Hi everyone!
          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
          06-27-2025, 08:54 AM
        • dellxps15
          macbook a1707 15 inch trackpad dead. blown fuse identification
          by dellxps15
          hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
          another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
          04-30-2024, 10:48 AM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • Flasman90
          Macbook Pro DFU Restore Issues
          by Flasman90
          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
          08-30-2025, 10:27 AM
