Aspire 7520 not power up
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Hi i have strange problem with this machine
    La-3581p
    when adapter on first i have 3,3v and 5valw ok BUT when i press power button not power and shorted 3,3v and 5valw . so no more 3,3 and 5v only short 0.1ohm resistance .
    Replaced : PU3 , ENE ic , PU11 , Bios IC , AND no change same short
    on my PSU do not consume current onle 090 amp .
    My doubt is IGP dead bu i cant confirm ?
    Any idea please i attach schema and boradview
  • mielta
    • Apr 2015
    • 368
    Re: Aspire 7520 not power up
    Hi
    Where is the short
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      it has mxm video card ? if yes try remove it and see what it does.
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        Thanks for reply no do not have grafic card .
        • gcomputers
          • Apr 2013
          • 509
          • Albania
          Originally posted by mielta
          Hi
          Where is the short
          The short is on 3.3v and 5 v so 3.3VALW and 5VALW are shorted after i press power button
          • mielta
            • Apr 2015
            • 368
            Hi
            by this Model often the mcp67 goes bad
            • gcomputers
              • Apr 2013
              • 509
              • Albania
              Hi
              Usually if the mcp67 is burned all caps on it are shorted but on this igp the caps are ok.
              And if is problem of mcp67 i think the machine start for one sec BUT in my case go in short 3.3-5VLAW this is strange?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                check for short on 3.3 and 5V switched rails.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • seppde
                  Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
                  by seppde
                  I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
                  My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
                  Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
                  Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
                  10-01-2024, 10:57 AM
                • Bonaventure Vigil
                  ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                  by Bonaventure Vigil
                  Dear All,
                  Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                  At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                  12-12-2024, 10:22 AM
