KB9012QF A3 chip on Dell 3521
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    I have a problem Dell 3521. That is +3.3V is short to ground. I try to inject 1.5 V to the Coil and i found heat on KB9012QF A3 chip. I removed it and check again now that short has gone. But i have KB9012QF A4 chip as replacement. Is it OK. That is KB9012QF A3 to KB9012QF A4.
  • katfish
    • Jul 2016
    • 76
    Re: KB9012QF A3 chip on Dell 3521
    Should be ok to swap A3 with A4. But ... you may need to program it.
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      Ok thanks katfish. I will try it. But at the moment i don't have the programmer for KB chip. My programmer not supporting to do it. I already ordered for RT809F it will take few days to reach me. First i will fix KB9012QF A4 to the motherboard and i will wait for the programmer.
      • katfish
        • Jul 2016
        • 76
        Yea, I've got one on order as well .... just did a new 9012 replacement. Waiting for the programmer too.
        It is possible to use a CH341a ... from what I was reading. But seems to be a pain to get going with it. Need a Linux system and the flashrom program, I think it's called flashrom.
        Here's a link to the DIY - http://dangerousprototypes.com/docs/...ith_Bus_Pirate
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          KB9012QF A3 = KB9012QF A4. 100% sure. Did it on dell 3521 . Need programming though
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Geeker007
            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
            by Geeker007
            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
            I am new to electronics repair, so my queries could be naive but I am ready to learn.
            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
            01-28-2025, 03:31 PM
          • ed1i
            Dell Inspion 7610 bios chip
            by ed1i
            Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
            01-16-2025, 02:14 PM
          • retrorepair2
            Dell E5470 LA-C631p - Short removed now turns on but no post/display
            by retrorepair2
            Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
            Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
            09-25-2025, 07:12 AM
