Dell Inspion 7610 bios chip
  • ed1i
    • Jan 2025
    • 9
    • Bulgaria
    Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?
  • b4uheart
    • Feb 2023
    • India
    Hey have you able to read write on this chip I also have ch341 programmer which tool have you used to do so for Winbond 25Q256JVEQ
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
      by SMDFlea
      Bad...
      09-02-2021, 04:40 PM
    • ngethin
      DELL Inspiron 16 7610 - Need help identifying BIOS chip please!
      by ngethin
      Guys could someone help please, I need a BIOS files but I can't figure out the BIOS chip on the motherboard to extract an image. I'll attach an image of the board, if someone that has some experience could point me in the right direction please. I already tried a WINBOND_25Q80DVNIG (1MB) to the right of the battery connector, and also a WINBOND_25Q16JWNIQ (2MB) at the bottom of the GPU but both the images are too small. Any help would be greatly appreciated!
      MB Part Number: 3765263 VER 1B
      DELL Part Number: 09FDV3
      Machine Model: Dell Inspiron 16 7610
      DELL Service...
      09-23-2024, 11:07 AM
    • ezenia
      Dell G3 3579 BIOS chip ID
      by ezenia
      I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
      06-16-2025, 08:07 PM
    • JoWed
      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
      by JoWed
      Hello Community,
      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
      07-01-2025, 09:32 AM
