Question about Notebook*Lenovo*IdeaPad*310*15ABR
  • Gianni
    • Jul 2008
    • 681
    • Italy
    I have bought this notebook because my old one Acer 5100 with AMD Turion 64 was too slow.
    I have choosen this one because I think it is enough for what I do and moreover was sold with 10% discount.
    Main features:
    WIN10 Home 64Bit
    CPU AMD A10-9600P
    RAM On-board + SO-DIMM (4GB On-Board) 12GB 2133MHz
    Display 15.6" 1366 x 768 pixels LED 16:9
    Graphic card AMD Radeon R5 M430 2GB GDDR3
    HDD 1000GB 5400RPM SATAIII
    After some days I was curious and I checked it with CPU-Z and with a big surprise it shows me RAM are working in single channel.
    Is it normal?
    I think yes because 4GB on board can't be identical to 8GB on SO-DIMM.
    Than does it make sense to have 12GB in single channel? Does it affect performances?
    Thanks for you answers
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: Question about Notebook*Lenovo*IdeaPad*310*15ABR
    Look this:
    http://www.gamersnexus.net/guides/13...nnel?showall=1
    • diif
      • Feb 2014
      • 6978
      • England
      Dual channel only works when both of the channels are populated with memory of the same speed and size in the correct slots. In reality it seems that its only certain software/tasks benefit from it.
      • Gianni
        • Jul 2008
        • 681
        • Italy
        Thanks for you answers and link, as far as I understand it is not so important for me.
        By the way, after posting here I serched with google and I found a thread on Lenovo forum, there is a guy with same notebook asking the same question.
        What I don't understand is why Lenovo reccomend to use "dual channel capable" RAM if they can't work in dual channel (see attachment).
        Have a nice day
        Gianni
        H. J. Brown
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • spleenharvester
          Reverse engineering of 18650 4-channel tester
          by spleenharvester
          Hi friends
          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
          05-04-2025, 02:43 AM
        • mikey5791
          Help on car amplifier only one channel works
          by mikey5791
          Hi all forum members,
          Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
          My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
          08-06-2025, 10:36 PM
        • dicky96
          American Audio VLP1500 Distorting on one channel
          by dicky96
          Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
          Protection and Clip LED are off
          There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
          I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
          The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
          07-13-2022, 05:25 AM
        • dicky96
          Hitachi V19B01922 Channel Tune problem
          by dicky96
          Hi Guys
          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
          He also has an LG TV, so three screens in the bar
          I installed three Satlink ST-6503 DVB-T Modulators
          This model https://www.aliexpress.com/item/32916553905.html
          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
          02-09-2023, 09:20 AM
