CQ61 no boot- Charge led off after seconds
  • Maxmad
    • Jul 2013
    • 63
    • Greece
    One more thread for this board. Seeking a lot old threads. No help.
    Bios already flashed with no result.
    Board shut off almost immediately after button pressed.
    When charger is plugged in the charge led is on for some seconds and then off.
    checked +3V_ALW +5V_ALW +12V_ALW all seems ok.
    Also immediately after button pressed checked the other voltages and seems to work before shut down.
    Only on PL7 there is no voltage. I can measure the battery's voltage when it is plugged in , but no increase when power button pressed. (logically this must be increased in order to charge the battery)
    AD_ID is 1.6v
    Should i try another bios flash or it is an electrical fault?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: CQ61 no boot- Charge led off after seconds
    This laptop model may be a CPU killer, especially the Athlon II model...
    The one I was working on, didn't shut off when dead, but did slow a slow blink that appeared to be a code #1, for CPU failure...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Maxmad
      • Jul 2013
      • 63
      • Greece
      No this model is the one with intel cpu.
      A lot of issues sure but trying for the best
      • tibd
        • Oct 2014
        • 189
        • Sweden
        start by flashing new bios
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          I second that. Looks like faulty BIOS. Have had the same thing with this model.
          • Maxmad
            • Jul 2013
            • 63
            • Greece
            bios already flashed...
            Used this file in this post:
            https://www.badcaps.net/forum/showpo...69&postcount=9
            I desolder the chip to verify again with the programmer.
            After all these tests, it seems ok. Verify passes 100%
            What's the voltage in BATCHG when the battery is plugged in ?
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              try to turn the laptop on without battery.
              if it does not work, measure voltage on all pins of ISL6251A after pressing the power button.
              • eigma
                Samsung UN40H5003 boot loop every ~8 seconds
                by eigma
                Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                Main board: BN94-07592P / BN97-08922R...
                11-20-2024, 10:31 PM
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
              • reeluff
                DELL XPS 15 9510 LA-K411P (NVDC ISL9538C) NO BOOT / NO CHARGE
                by reeluff
                Device history > Bit of liquid damage, that I cleaned up and sorted out all bad components.
                Current state > No Boot. No charge. It negotiates 20v on all USBC ports, and will even PD charge out – so all of the USBC circuit is probably ok. I have 3.3V + 5V ALWP present and stable. PCH has its 3V,1.8V,1V. On the board, PCH,EC,ISL,PD chips are all powered on and active. Power button has 3V, board is being signalled by it but not responding. I have 20V USBC in OK, I have a 12.6V main power rail ok. The battery was undervolt dead, so had to manually charge each cell individually...
                02-09-2024, 09:37 AM
              • koriwi
                P14s Gen 2 AMD; no boot, no image, no backlight, no charge
                by koriwi
                Hi guys, I am new here, but I've tried my best to read up on the beginner guides and reading some other threads. So here the base information i can provide.
                -Lenovo P14s Gen 2 AMD
                -Ryzen 7 5850u
                -16GB soldered (32GB stick added, removed for debugging)
                -256GB SKHynix SSD (removed and swapped for debugging)
                -NM-D451 Motherboard (P/N: 5B21C82277)
                -S/N: PF-34N64A
                -Model: 21A0-000QGE
                History and symptoms:
                I had this Laptop for some time but stopped using it (installed Linux, worked perfectly) as I changed company and got a MacBook...
                03-08-2025, 05:22 PM
              • privato89
                Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                by privato89
                I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                Let's begin:
                Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                03-26-2024, 06:37 AM
