Sony VGN-SZ3XP (PCG-6N2M) no backlight.
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello.
    I receive a VGN-SZ3XP Sony Vaio model with no backlight, it has LED screen so no inverter problem, i changed screen but still no backlight so i guess no problem on screen it self and/or in the attached board.
    I want to know which one is the backlight voltage to follow it from mainboard to LVDS flex and found out where it stops.
    Thank you in advance!
  • BlueMidnight
    • Jan 2015
    • 489
    Re: Sony VGN-SZ3XP (PCG-6N2M) no backlight.
    Can you see an image at all if you shine a light on it? Is it truly just the backlight? Do you get an image through the VGA port? That model is actually a bit older and has an nVidia G72M GPU. That's one of the ones nVidia officially admitted were prone to failure.
    Everything pretty much goes straight to the GPU. The backlight enable and control lines do go through a multiplexer chip (IC760) to select whether they are controlled by the northbridge or the discrete GPU. And there are also some pull-down resistors on those lines.
    The backlight enable line also goes through IC3200, which is just an AND gate. If both pins 1 and 2 are high, then pin 4 is high. Otherwise pin 4 is low. So you can just make sure all three of those pins are high..
    I'm not 100% sure what the voltage is supposed to be on those signal lines, but it's probably 5V if I had to guess.
    And there is also 5V supply voltage at the LCD connector pins 1 and 2.
    And that's about all.
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      Yes i get image if i shine light on it and i get image from VGA port too.
      I was thinking that perhaps is the flex cable that's why i want to follow the line and found out where it stops.
      I'll check IC3200, thank you!
      • HTR-Informatique
        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
        by HTR-Informatique
        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
        I also changed the screen because the PC fell and the screen was broken.
        I changed the battery with a new and original battery.
        I also had corrosion/oxidation on the...
        02-09-2025, 06:51 AM
      • frannyjunk
        Hisense 40H4F no backlight but turns off after splash screen
        by frannyjunk
        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
        TIA.
        09-24-2025, 10:59 AM
      • turmix
        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
        by turmix
        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
        During another reassembly, I made a mistake, and...
        01-29-2024, 03:48 AM
      • FallenOne008
        Asus G712L No Screen Backlight
        by FallenOne008
        Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
        The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
        03-31-2025, 08:27 PM
      • Audeze
        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
        by Audeze
        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
        Does...
        10-06-2024, 08:54 PM
