Alienware 17 (R5) shorted Mosfet
  • Grishnackh
    • Jul 2016
    • 22
    • Austria
    Hello Guys,
    i have a Problem with my Alienware 17 (R5), it´s the LA-9331P Board. I dont know excactly what happend with this Alienware i got it functionless. I detected that the Power Supply was faulty (it was a DA180PM111 19,5V / 9,23A), so the Notebook didnt started. I bought a new Power Supply, it is a mtXtec 0J211H 19,5V / 12,3A. When i pluged the Power Cord to the Laptop something blown. It was the PQ502 - MDU1516 which burn out. Could someone tell me what could be the reason? I measured the Voltage on the 0J211H, for less then one second i have about 30V, and then it varies between 18V - 22V.
    Can someone tell me if the Power Supply is faulty? I checked the manuel of the MDU1516, he should take up to 30V max. So why is he blown?
    Greets, Grishnackh
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Alienware 17 (R5) shorted Mosfet
    we need schematic.
    • polytek
      • Dec 2013
      • 496
      • TUNISIA
      check your cpu PQ502 cpu vcc
      here is the sch:
      [MOD EDIT] Link to schematic https://www.badcaps.net/forum/troubl...331p-schematic
      • Grishnackh
        • Jul 2016
        • 22
        • Austria
        @polytek - thank you for you help, i measured the ohm - like shown in your picture - to ground, and it´s about 0,2 Ohm. I hope i did it correct, because it has only two pins (see picture). Should i measure the voltage too? I am afraid to burn another mosfet - i already removed the burned PQ502.
        Greets, Grishnackh
        • koresi
          • Sep 2012
          • 24
          • Romania
          hello
          where did you measure 0.2ohm?between pl501 and ground?
          do this measurements(before that remove the cpu):
          pq502 pin4 and gnd
          pq502 pins1,2,3 and gnd
          pq502 pins5,6,7,8 and gnd
          pq502 pins1,2,3 and pins5,6,7,8
          • Grishnackh
            • Jul 2016
            • 22
            • Austria
            Originally posted by koresi
            hello
            pq502 pin4 and gnd
            pl501 to ground -> 0,1-0,2 Ohm
            pl502 to ground -> 0,1-0,2 Ohm
            pq502 pin4 and gnd -> 22 MOhm
            pq502 pins1,2,3 and gnd -> 0,4 Ohm
            pq502 pins5,6,7,8 and gnd -> 33 MOhm
            pq502 pins1,2,3 and pins5,6,7,8 -> 19 MOhm
            Greets, Grishnackh
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              No , if that mosfet is burning ITS BECAUSE OF u GATE AND l GATE , post values of does gates here please and also chek pc503 to pc507 , lift the mosfet that is burning , and remove the side one as well , and chek the capacitors for short . give us this infos , seems a easy fix , just needf to know values to give you right direction
              • koresi
                • Sep 2012
                • 24
                • Romania
                ok,so you have a shorted component on +vcc_core signal.you have to check all components connected on +vcc_core and ground.on the left side of pl501,pl502,pl503 you have pq503,pq504,pq507,pq508,pq5011,pq512,pu500.On the right side you have a bunch of capacitors :pc900,pc901....
                if you can't measure the faulty one all you can do is remove one,measure,put it back and so on until the short goes away(the measurement has to be tens or hundreds of kohms).
                goodluck.
                • Grishnackh
                  • Jul 2016
                  • 22
                  • Austria
                  thank you all for your help so far....what i found out, is that PL501 seems to be defect or theres something wrong. I removed PL501, PL502 and PL503. Only PL501 (i called it "A") "A" has a connection to ground - that shouldnt be, "B" where connected with "B" from PL502 and PL503. PL502 and PL503 both "A" doesnt have connection to ground. When PL501 was on board, PL502 and PL503 also the little capacitors between PL502 and the CPU Socket were shorted. So i think i should go back the way from PL501 "A" - but which Pin from the Schematic on the PL501 (2, 3, 4) i should take?
                  Greets, Grishnackh
                  • koresi
                    • Sep 2012
                    • 24
                    • Romania
                    pin4.
                    so only pq503,pq504 or pu501 is potential defective.i will go to pu501 (mosfet driver).
                    • Grishnackh
                      • Jul 2016
                      • 22
                      • Austria
                      I think its PQ503 and PQ504 - both are shorted at least i have direct connection from Drain to Source. Is this my problem?
                      Other Mosfets PQ507, PQ508, PQ511 and PQ512 doenst have direct connection from Drain to Source.
                      Greets, Grishnackh
                      • Grishnackh
                        • Jul 2016
                        • 22
                        • Austria
                        @Koresi i think you are right....on PU501 Pin 4 (GND) is connected to PIN 8 (PHASE3) and continue to Drain to Source from PQ503 and PQ504. So i could only be the PU501 or? Could anyone has information where to get this part in europe or a comparable to ISL6208BCRZ-T?
                        Greets, Grishnackh
                        • koresi
                          • Sep 2012
                          • 24
                          • Romania
                          http://www.ebay.com/sch/i.html?_from...CRZ-T&_sacat=0
                          • Grishnackh
                            • Jul 2016
                            • 22
                            • Austria
                            Thank you, i ordered it on aliexpress and the PU500 too - Do you think changing the PU501 will solve my problem?
                            • koresi
                              • Sep 2012
                              • 24
                              • Romania
                              did you remove PU501 and short gone away?
                              • koresi
                                • Sep 2012
                                • 24
                                • Romania
                                oh sh... yesterday I wrote pu500 instead pu501,my bad.it's about pu501 not pu500 ,sorry.
                                yes I think that changing pu501 will solve it.
                                • tata123
                                  • Nov 2013
                                  • 104
                                  @ Grishnackh was genau war mit deinem Alienware, ging auch dein Netzteil nicht mehr?
                                  Habe auch son änliches Problem...
                                  Hoffe mal deiner geht wieder?
                                  • Grishnackh
                                    • Jul 2016
                                    • 22
                                    • Austria
                                    @koresi Thank you, i removed the PU501 and the short circuit is gone...hope to get soon the new one to test it.
                                    @tata123
                                    Ich kenn die Vorgeschichte leider nicht, ich habe das Alienware defekt gekauft - lt. Verkäufer war das Mainboard defekt bzw. lies sich er sich nicht mehr starten. Als ich es erhalten habe, stellte ich fest, dass das Netzteil nicht geleuchtet hat und auch keine Spannung raus kam. Daraufhin habe ich mir ein neues Netzteil bestellt, den Laptop angeschlossen und bemerkt dass es irgendwo raucht -> es war der Mosfet PQ502. Habe dann durchgemessen (siehe Thread) und stellte fest, dass PU501 von Pin 4 auf Pin 8 einen Kurzschluss hat, wodurch -höchstwahrscheinlich- der PQ502 durchgebrannt ist. Habe jetzt mal die Bauteile bestellt und werde berichten sobald ich sie eingebaut habe.
                                    Greets, Grishnackh
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      check why short happened too...... in many of pc with shorted circuit, when problem was not a capacitor but a mosfet, i got also bad gpu-cpu ram that caused the issue.
                                      if u got short on cpu rail, check that cpu on some other laptop if u can.
                                      this is just a suppose. could be easly possible that after mosfet replacement pc will work fine .
                                      • tata123
                                        • Nov 2013
                                        • 104
                                        Grishnackh, danke für die ausfürliche fehlerbschreibung....
                                        yes most common shorts are on mosfet's or caps....
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • chestercc
                                          Alienware M18x Shorted CPU Mosfet
                                          by chestercc
                                          I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                                          I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                                          Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                                          07-16-2022, 06:05 AM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
                                        • mat2k
                                          iMac 2017 PSU - shorted PFC mosfet
                                          by mat2k
                                          I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                                          There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                                          03-13-2025, 11:31 AM
                                        • daemon123
                                          MSI GTX-980ti shorted MOSFET on memory rail
                                          by daemon123
                                          Hi All,
                                          I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
                                          What should be the next step. Kindly guide.
                                          The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
                                          05-10-2023, 11:05 AM
