Help needed please!!Asus X55A-SX119H display problem
  • Giff1711
    • Mar 2012
    • 34
    Hi there, need a little help
    I have a Asus X55A-SX119H with the B830 cpu. https://www.asus.com/Notebooks/X55A/specifications/
    When i power it on it shows the asus logo then goes blank, the back lights are working you can see the screen lit up, the hard drive light comes on for about 30 secs & the cd works. But i am unable to access bios or any boot menu, if i attach a external monitor i get a total blank screen not even the logo. I was thinking it could be the bios but the battery charging led works & hd led & cd spins. If its not the bios could it be a graphics issue on the processor side has this cpu has intel hd integrated graphics. Its just weird how it shows the logo then goes blank every other graphics issue i've had its blank the second you power on ?
    Any help would be much appreciated, I have attached a video so you can see the problem
    Thank you
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Help needed please!!Asus X55A-SX119H display problem
    if you have eeprom programmer read old bios and post here i will fix it for you
    Im Back... sort of...
    • MJ-meo-dmt
      • May 2016
      • 186
      • South Africa
      Hi Giff1711
      Have you tried starting it without the extras... Like take out the HDD and the CD Drive. Esp the HDD...
      Oh and also try it with out the KB if you can...
      Also when you tried it on the external monitor did you do it via old VGA analog or HDMI? Sometimes when you have dedicated cards you'd get something on the analog side and not the HDMI... But i don't think that's the case here as that CPU has Intel® HD Graphics embedded.
      while alive { live(toFullest=true) }
      • kotel studios
        Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
        by kotel studios
        Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
        State I got it in:
        Squealing from the PSU
        After logo I get a blank screen
        After 10 seconds of having a blank display w/ backlight the TV dies
        Give it 7-10ish seconds again and it starts to bootloop.
        What I did so far:
        Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
        Checked all voltage rails:
        5VSB - 4.8V
        AMP+13V - 14.4V
        13V - 12.98V (in manual 12V)...
        09-21-2025, 02:00 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • rattlesnake
        Voltage issues SY-5SSM, where's the problem? Help needed
        by rattlesnake
        I'm trying to fix this SY-5SSM motherboard (Socket 7).
        When the PSU is connected it powers on by itself but there's nothing on the POST card, no beeps.
        The BIOS EEPROM is ok (latest BIOS was flashed).
        All the jumpers are set ok.
        All the 1000µF 6.3v (14) and 1500µF 16v (2) caps are in spec.
        There are two 76129D MOSFETs (datasheet). I took them out and tested them and they are ok (no continuity from drain to source) in off state.
        But the voltage in the gate of the second 76129D fluctuates between 1.468-1.649,...
        01-26-2025, 11:26 AM
      • MICHAEL_2013
        Change Logo Aptio Setup Utility 2021 (ROM Layout mismatch detected) Problem
        by MICHAEL_2013
        Good afternoon, Lords of great wisdom. My problem is the following: I bought a Chinese laptop with GN117_MB_V31-T board. (Aptio Setup Utility 2021) (There is no info for that board). And I want to change the logo of the bios. I have used Aptio_V Afuwin to do the bios Backup, then I change the logo with AMI ChangeLogo Tool v5.0.0.2 and everything seems perfect. But when you restart the new logo appears ok. But it automatically enters the bios, appearing a new option RECOVERY, ROM LAYOUT MISMATCH DETECTED - PARTIAL UPDATE IS NOT ALLOWED. If I give ESC it enters windows without problem but always...
        06-28-2021, 03:12 PM
      • Ardent1
        Lenovo IdeaPad 3 15IIL05 81WE New Blank Chip - help needed
        by Ardent1
        Hello everyone, I have never flashed a bios before and currently find myself needing to flash a new Winbond W25Q128JVSQ chip without the original bios file.. I have a CH341A programmer and have been able to connect the chip to neo-programmer, but that's about as far as my knowledge takes me so far. When i read the chip the data appeared to be all FF for every entry.
        I do not know the history of the motherboard, only that the old chip was removed because it was dead apparently. When the on button is pressed, the laptop on battery alone just shows a solid white light on the side and same on...
        12-18-2024, 02:52 PM
