HP DV2945SE POST failure
  • tr4nshum4n
    • Apr 2014
    • 6
    Hey, everyone!
    I'm researching to troubleshoot my old laptop.
    Model: HP DV2945SE
    Motherboard markings: TIBET MB 06241-3M
    Current State:
    When I power the unit on, the power button LED and motherboard LEDs light up. The CPU fan turns on. LCD screen does not give display. I removed RAM modules to see if I get a POST error beep. The unit does not beep.
    History:
    I replaced the motherboard button battery, and afterward the unit wouldn't boot. I tried removing and replacing the RAM modules, and then it booted once. After a few minutes, I received a faulty display.
    This was a few months ago, so I can't remember exactly what the screen looked like, but I remember it was garbled, and my system appeared to be frozen. I was using LXDE with Debian Linux at the time. I shut down using the power button, and ever since then it hasn't finished a POST.
    I have held the power key down for 1-minute with battery and power removed, and I have also allowed the motherboard to operate on the battery until the battery was drained. Still no beep.
    Questions:
    1. I've attached a motherboard schematic document that appears to be a match, but it's only titled TIBET, rev SA. I was unable to find the identifying number 06241-3M. I've spot checked, and it appears to match my model. I got it from http://www.s-manuals.com/motherboard/wistron_tibet. Is there a way I can be certain I'm looking at the correct drawing?
    2. Some motherboards have 3VALW and 5VALW. I was going to begin by checking for these voltages. I didn't see them labeled in the schematic. Is it possible my board doesn't have them?
    3. I've read a brief description of checking POST status by monitoring for current changes: http://ng.laptoprepairtrainingcollege.com/tblog.html, search for DV6000. Is anyone familiar with this? Where do these currents show up?
    Thanks a lot for any input!
  • crazykill
    • Jun 2016
    • 11
    Re: HP DV2945SE POST failure
    Sp fan spins it may be something with the video output.Try an external monitor.If you still don't get signal maybe you GPU is fried.
    • tr4nshum4n
      • Apr 2014
      • 6
      You're right, there could be a problem with the GPU. I think I've tried the external display approach before. I'll give it another go when I get home.
      I don't think the GPU is the problem here, though. I would still expect an audible alert if I tried to boot without RAM, and I'm not getting that.
      • tr4nshum4n
        • Apr 2014
        • 6
        I tested with an external display, and I didn't get an image on the laptop monitor or the external monitor.
        Would a faulty GPU cause a failure to POST?
        • MJ-meo-dmt
          • May 2016
          • 186
          • South Africa
          Hi, tr4nshum4n
          To be honest everytime I see anything HP DV xxxxxxx. I just switch on my hot air station and take out the liquid flux. *ready to reflow that GPU.
          Of everything you explained I put my money on the GPU being the issue here.
          But yeah small chance that it could be something else.... but i doubt it.
          Good luck tho...
          while alive { live(toFullest=true) }
          • tr4nshum4n
            • Apr 2014
            • 6
            Thanks a lot for the suggestion!
            I gave a reflow a shot (this is the second time for this laptop), and it worked like a charm!
            • samanthban
              • Feb 2014
              • 253
              • Sri lanka
              you can use it for one or two months.
              sigpic
              • JoSsLxD
                • Sep 2018
                • bolivia
                Sombody has boardview for wistron tibet? help!!
                • glovecaps
                  by glovecaps
                  11-25-2024, 04:23 PM
                • fixme2024
                  Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
                  by fixme2024
                  Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
                  Here, I have attached a document...
                  02-14-2024, 09:24 PM
                • Archimedes
                  HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                  by Archimedes
                  Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                  Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                  Fans are spinning. Blindly could install windows11 and got the device manager...
                  07-30-2024, 05:14 PM
                • dhenion
                  Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                  by dhenion
                  I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                  The original board was:
                  ASUS X510UNR REV 3.0 A
                  The replacement board is:
                  ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                  It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                  01-30-2024, 01:45 PM
                • Mess
                  Motherboard diagnostic beginner advice
                  by Mess
                  To save you some time: the most important bits are in bold.
                  Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
                  Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                  09-12-2024, 07:02 PM
