Asus N71VN burned Power Connector
    • 31256
    Re: Asus N71VN burned Power Connector
    nice vid, makes me wonder where the hell it's getting the + from!
    maybe peeling that top track away would stop it.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      #42
      LOL, after the dremel it worked on first attempt !
      I don't have anymore the short between + and -, it's better if i resolder backe the inductors and capacitor ?
      Crazy, you really need to remove all the charcoal, otherwhise short will remail !
      Thank you all of you buddys
      PS: Now need to run final tests
        • 31256
        that's a big hole!
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          #44
          Originally posted by stj
          that's a big hole!
          Yeah, now it's just a big hole, not a Black one
          Just finish solder back the 4 removed smd's, now will rest before i atempt to put back the connector
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            #45
            Ok, pc is 100% Working, battery is charging !
            The + Pin of the power connector is not touching the mobo, i used a wire to connect on the other side.
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
            • Duranitron
              Asus x512dk rev 2.1 power on problem
              by Duranitron
              When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
              Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
              11-26-2024, 10:22 PM
