Asus N71VN burned Power Connector
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Asus N71VN burned Power Connector
    Is this socket that you are talking ?
    Pin is strait ?
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      I think that i damned, i still have a short between - and the H6538 Point ...
      Normal or Not ?
        • 31255
        ok all is good.
        that pin probably wont bend, cut it so it wont go into the board.
        then put the connector on the board and put a thick jump wire between the back of the socket and the place the 3 inductors went to.
        then test it.
        if it works and charges, we can do it better with the inductors and cap back in use.
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          Originally posted by stj
          ok all is good.
          I need to resolder the 3 inductors ?
          If Not, where should i solder +19V ?
            • 31255
            this is where you want the socket pin to connect.
            you can use a wire,
            but even better, if you can put the inductors back standing vertical with the wire across the top of them.
              • 31255
              wait - i have a better idea - making a foto now.
                • 31255
                like this:
                put the inductors back facing the other way.
                then put a wire across them.
                • WINJOKE
                  Banned
                  • Jan 2014
                  • 27
                  Hi everyone im not able to make a new post because im a new momber but i hop to get your help about my probook 650 : i need bios fil ,the part number of yhe mainboard is 6050a2566301-mb-a03
                    • 31255
                    i think you can make a new post, who makes your laptop?
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      #30
                      Before your Sugestion i've tried this (photo) :
                      Once i approach the Ground to any of the - Poles, i get sparks .
                      As you can see, i continue to grind/sand, and the short is still present on this area.
                      EDIT: in my humble opinion, the short is on the - ground side, then i'm ....
                        • 31255
                        if you put 19v on the pads that connect to the fet, does it work?
                        • passete
                          Living=Sharing
                          • Jun 2015
                          • 487
                          • France
                          #32
                          Can you point this pad ?
                            • 31255
                            i did - in my foto
                            • passete
                              Living=Sharing
                              • Jun 2015
                              • 487
                              • France
                              #34
                              i did - in my foto
                              This is what i've done on post 30.
                              Sparks on, when i connect the - on the short area
                                • 31255
                                so you put - on the area for -,
                                and + on the marked area, but NOT in the original hole in the board?
                                • passete
                                  Living=Sharing
                                  • Jun 2015
                                  • 487
                                  • France
                                  #36
                                  Ok, let try to explain, see the photo posted.
                                  +19 was soldered on the midle pad
                                  Ground or - was aplied on lower left hole, like on the photo.
                                  Hope that you understand what i'm trying to explain
                                    • 31255
                                    o.k. where was the spark?
                                    • passete
                                      Living=Sharing
                                      • Jun 2015
                                      • 487
                                      • France
                                      #38
                                      Near the center of the black hole area, lol !
                                      On that region.
                                      • passete
                                        Living=Sharing
                                        • Jun 2015
                                        • 487
                                        • France
                                        #39
                                        Here a little video of the sparks
                                        Maybe it's time for the Dremel, like someone sugested previously , lol
                                          • 31255
                                          let it spark till it's burned away!
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • ShadowAi
                                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                            by ShadowAi
                                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                            03-15-2024, 10:46 AM
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
                                          • Duranitron
                                            Asus x512dk rev 2.1 power on problem
                                            by Duranitron
                                            When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                            Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                            11-26-2024, 10:22 PM
