T410 strange problem
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Re: T410 strange problem
    No the fan its brand new.
    • atsio
      • Oct 2013
      • 819
      • Greece
      Voltage on pin 32 of U42 from the moment you press power button
      • rippergr
        • May 2014
        • 345
        • Ελλάδα
        I was just ready to write those voltages.
        Ok for pin 32 when I press the power button the voltage is 2,5V and the fan is on, it stays like that for 2-3 seconds and then the fan goes off and the voltage goes 3,58V
        On pin 33 the voltage is 1,7V fan on and after 2-3 seconds the fan goes off and the voltage is 3,28V
        After that the voltage stays at those values and the fan is off
        • atsio
          • Oct 2013
          • 819
          • Greece
          Jumper 5v voltage from fuse F4 to pin 1 of J15 and monitor the voltages on pin 3 of J15, and pins 32,33 and 34 of U42
          • rippergr
            • May 2014
            • 345
            • Ελλάδα
            It is very dificult to jumper f4 with pin1 on j15 .I already broke the one end , can I give 5 V with my bench power supply directly to pin 1?
            • atsio
              • Oct 2013
              • 819
              • Greece
              #26
              Yes, do it.
              • rippergr
                • May 2014
                • 345
                • Ελλάδα
                #27
                I have 1,5V in pin 32
                1,4V in pin 33
                and 0V in pin 34
                Fan is always on.
                The problem is that it gives me the 1-3-3-1 beep error. Sometimes it starts without touching any connection just leaving it without power for a few hours. When I try it again it starts ok but the fan is not working always.
                • rippergr
                  • May 2014
                  • 345
                  • Ελλάδα
                  #28
                  Today the laptop works like nothing happened.
                  The fan spins ok and I have in pin 34 0,38V
                  Pin 32 1,88V
                  and pin 33 1,43V
                  Everything seems to working great and I didn't touch anything. I left it two days on my bench and put it on plug today.
                  If I close it now there is high possibility that it wont turn on again and just give me the 1-3-3-1 beep error ,and all this without toucing anything .
                  • rippergr
                    • May 2014
                    • 345
                    • Ελλάδα
                    #29
                    UPDATE:
                    If I leave the laptop on and use hybernate or sleep everything works fine. If I shutdown and try to reenable it it gives me the 1-3-3-1 error code and the voltages are not correct.
                    Even if I give 5V to the fan it doesnt boot.
                    Can I inject voltage to fan control to "trick" it that the fan is ok?
                    • qonma
                      Kuli Solder
                      • Jun 2017
                      • 184
                      • INDONESIA
                      #30
                      we have same problem
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3581
                        • slovakia
                        #31
                        fan spin is detected by FAN_FRQ signal. check voltages on R421 and q81 do u have scopeto check fan_freq signal?
                        • pkslowk
                          Debug Card Error Code and Solution
                          by pkslowk
                          Sr. Motherboard Debug Error Code Solution
                          1 Intel 845 E9 Bios Related Problem
                          2 Intel 845 D4 CPU Socket Related problem
                          3 Intel 845 37 Bios Related Problem
                          4 Intel 845 7C Bios Related Problem
                          5 Intel 945GCPE 34 Bios Related Problem
                          6 Gigabyte 845 2 Ram Related Problem
                          7 IBM Server A6 A7 Ram Mismatch Problem
                          8 Asus 845 29 CPU Related Problem
                          9 Lenovo I946 97 C-Mos Jumper related
                          10 Gigabyte 845 A0 CPU Related Problem
                          11 Asrock G31M-VS D7 Bios Related Problem
                          12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                          01-28-2021, 12:51 PM
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • Zeonalbasta
                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                          by Zeonalbasta
                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                          09-13-2024, 01:17 PM
                        • Gibon378
                          Problem with stopping audio and video for no reason
                          by Gibon378
                          PC Specs:
                          • CPU: Ryzen 5 1600
                          • GPU: GTX 1080 Palit JetStream
                          • MOBO: ASRock ab350 PRO4
                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                          • PSU: XFX 650W (don't remember what model)
                          • OS SSD: ADATA SP920
                          • OS: Windows 10 21H2
                          Problem description:
                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                          11-19-2022, 09:41 AM
                        • perzyk23
                          Lenovo T580 - LCD Panel problem - error 0288
                          by perzyk23
                          Good morning,
                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                          10-25-2024, 12:42 AM
