Hp 15-F125wm power issue
  • mcross
    • Sep 2011
    • 201
    i have a hp 15-f125wm that will power on with a charged battery, but will not with a known good charger and have changed dc jack. , no light when plugged in. also meter shows a short , when tested with power voltage is low and unstable at the connector on mobo, I had 2 and used the other to charge battery and testing
    thanks
    Mike
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Hp 15-F125wm power issue
    I assume you've having quanta u88m, so schematic not available. check if PD7 and PQ21 has shorted.
    attached datasheet and photo as reference
    - full photo link : https://www.dropbox.com/s/sn08djr4yt...MB6A0.rar?dl=0
    - credit to gs84 at http://notebook1.ru/
    • samanthban
      • Feb 2014
      • 253
      • Sri lanka
      Many times found faulty fets near to dc jack or protection circuit
      sigpic
      • mcross
        • Sep 2011
        • 201
        I will check and let you know what i find
        Thanks for the help
        • laptech
          • Sep 2014
          • 25
          • pakistan
          Re: Hp 15-F125wm
          quanta u88m, schematic
          • smali
            • Sep 2014
            • 287
            • Pakistan
            Re: Hp 15-F125wm
            Ya lo mary bhai..app na itnay puranay thread ma request kia.
            lets check this.
            • 580shahzad
              • Jan 2012
              • 61
              • PAKISTAN
              Re: Hp 15-F125wm
              thank bahi g
              • swanand
                • Dec 2011
                • 50
                thanks sir
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  thanks
                  • lpraderi
                    • Dec 2017
                    • 30
                    • Uruguay
                    I am looking for same main (U88M) boardview:
                    Quanta U87 U88M DAU88MMB6A0 REV A - BoardView (.BDV)
                    Mobo is in power loop ( 2 - 10 sec on/off ) power led, all switched ( S5) voltajes.
                    Found it shorturl.at/lpsyJ in ****************, but dont have enought rights.
                    • gerardo
                      Engineer
                      • Feb 2016
                      • 59
                      • Argentina
                      Re: Hp 15-F125wm
                      Thank you!
                      • thecro
                        • Jun 2019
                        • 6
                        • México
                        Re: Hp 15-F125wm
                        thanks, it helped me with a shorted board.
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • justice171
                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                          by justice171
                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                          1. Verified that all critical voltages are present:
                            • 3.3V and 5V are always present if DC is plugged.
                            • 1.8V on the BIOS chip is present.
                          2. Checked the power button functionality:
                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                            • Confirmed connectivity is intact, ruling out issues
                          11-26-2024, 12:39 AM
                        • SuperJames
                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                          by SuperJames
                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                          Specs
                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                          Backstory
                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                          10-23-2023, 04:09 PM
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • bcstedt
                          LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                          by bcstedt
                          LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                          Problem:
                          On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                          It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                          01-18-2024, 01:03 PM
