[help]Macbook pro 15 a1286 won't power on
  • phantomEVO
    • Mar 2013
    • 509
    a friend of mine gave me a macbook pro 15 (model a1286, md318LL/a) to upgrade ram and hd. but it doesn't power on. it totally dead. if i push the battery button, i've no led. the magsafe is with a green light. power button of the keyboard is ok. only one time i was be able to power on it.
    the only way to power on it, is disconnect the battery, hold power button, connect the power adaptor, keep holding power button than release power button and push power button. in this way, the mac power on with fans at full speed, i can launch disk utility but after some seconde, it power off.
    the power supply is a 60w i don't think it is the power supply...
    could you help me?
    sorry for my bad english
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: [help]Macbook pro 15 a1286 won't power on
    Make sure the Ram is seated correctly. Both sides should be plugged in and they should of heard a click when the metal locks clicked into the side of the RAM board. Also make sure the HD is seated properly. If you have done this then the next thing is use an external monitor and see if the internal screen is bad. You will have to try and switch form the internal screen to the external screen if this is not detected automatically. Then after that you can go to this thread to see what is involved in trying to trouble shoot a power problem on the board. https://www.badcaps.net/forum/showthread.php?t=52450
    • phantomEVO
      • Mar 2013
      • 509
      ac is totally dead so it is not a screen problem
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Are you meaning the DC plugin adapter? What AC? Do you have a schematic for it? I reread your first post. You said you were able to get into the disk utilities. Did you try putting back the old ram and HD? It sounds like a software problem. Did you try to do a recovery. I forget which button that is. Should be in the manual. I do not know if Apple has ever done locking up one hard drive to one machine. I know PC manufacturers have done this.This is done on the motherboard. I guess I would return it to the state that you got it from your friend and try to do a recovery.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          The other thing is you may have a bad thermal sensor which is shutting it down or the program that reads the thermal sensor is corrupt and then that is shutting it down. If the fans are at full blast. I would think that is because they are being told to do that. Either the software is corrupt and causing this or the sensor is bad. The only other possibility might be a open circuit in the thermal sensor line. Perhaps an open would be read as a hot temperature? I would observe a good Apple computer and see what the fan does on start up.
          • phantomEVO
            • Mar 2013
            • 509
            Sorry my english is very bad!
            i meant MAC and not ac!
            the mac is totally dead: no power at all, no fan spin, no sound. no led for the battery status and green led from magsafe. it is not a memory problem because the problem is also with old ram. the strange thing is that sometimes it boot.
            there is only one way to power on it every time
            disconnect the battery, hold power button, connect the power supply, keep holding power button, then release the power button and then push again power button.
            in this way the mac power up but after some minutes it power off
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              15 inch macbook require 85 watt psu.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                You said you were able to get to the disk utilities screen correct? If yes, have you tried to do a system restore? You hold down the command key and R key on boot up. Better yet try booting into safe mode. You can find these options at this link.
                http://www.howtogeek.com/189104/trou...artup-options/
                • phantomEVO
                  • Mar 2013
                  • 509
                  so could it be a psu problem?
                  • phantomEVO
                    • Mar 2013
                    • 509
                    so with the 85w adapter it boots without problem but power off itself during loading machos. if i stay in the screen where i have to choose from which disk i have to boot, i does not power off.
                    last thing. when i insert the power supply, it power on itself
                    • phantomEVO
                      • Mar 2013
                      • 509
                      i think i've found the problem: disconnecting the keyboard flex, i can boot without problem the macbook...so maybe i should change all the keyboard? :S
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        yes those macbook keyboard fails very often. try another keyboard if works fine.
                        • phantomEVO
                          • Mar 2013
                          • 509
                          so i can't fix only the button?
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Most likely by the time you get the parts to try and fix a keyboard that already has failed you could buy the whole keyboard new. They are pretty cheap.
                            • phantomEVO
                              • Mar 2013
                              • 509
                              what i don't understand is: why if go to the disc selection screen (with alt key) it doesn't power off. i'm scared that the problem is not the keyboard.
                              but i know that if i disconnect the keyboard i can boot fine the macbook
                              • phantomEVO
                                • Mar 2013
                                • 509
                                another strange thing. (with keyboard disconnected): as soon as i put the power supply, the macbook boot up
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  try an usb keyboard if works fine.
                                  if u disconnect keyboard, u power it by smc bypass or macbook power on itself ?
                                  without keyboard, macbook works fine? are u able to log into osx desktop ?
                                  that is normal. after u put battery back in it do a pram reset and all wil lbe ok.
                                  • phantomEVO
                                    • Mar 2013
                                    • 509
                                    ok i've installed a new keyboard and now it doesn't power off anymore. the problem is that i'm not able to boot from usb to format the new ssd and install el capitan. the loading is super super slow and i don't understand why. i've formatted two type of usb with different version of el capitan but it's impossible to boot from the usb.
                                    now i'm connecting via usb the old hard drive with the old operating system, but it seem also super slow
                                    • phantomEVO
                                      • Mar 2013
                                      • 509
                                      ok with the old hard disk, it boots superslow, but it boots. strange thing is that the date is wrong.
                                      but however it seems to work without problem...
                                      other strange thing: when i power on, i've not chime, even if it boot to the system....
                                      • phantomEVO
                                        • Mar 2013
                                        • 509
                                        please suggest me something to do!! i'm going crazy!!!
                                        like 1 hours to format the ssd, then reboot and i'm stuck at 5% of loading bar!!! why?!?!?!?!?!
                                        in the while i've done the pram reset and now i've the boing
                                        • themosttogain
                                          HP Envy 13-BA1565na with intermittent power button
                                          by themosttogain
                                          Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                          07-12-2024, 03:03 AM
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • reessi
                                          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                                          by reessi
                                          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                                          No corrosion any where!
                                          Tried a replacement power button off ebay and the same.
                                          Very occasionally it will work with the power button connected!
                                          Same results with or without the battery.
                                          Can it be a fault with the Audio board or the mainboard?
                                          The touch Id assembly connects through the Audio board first then to the Mainboard.
                                          Flex...
                                          06-26-2024, 03:31 PM
                                        • Darren Hibbert
                                          MacBook A2179 Audio board+Power button boardview & schematic needed
                                          by Darren Hibbert
                                          Hi.
                                          Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
                                          There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
                                          Many thanks. ...
                                          08-21-2025, 02:38 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
