Garmin 530 HCx
  • AMstrick
    • Mar 2016
    Garmin 530 HCx
    Hello all,
    Have a Garmin 530 HCx that I am looking for some assistance with resolving a technical problem.
    During normal use, across the top of the screen there are several icons. One of which is the battery status indicator. When the Lithium Ion battery is used, I get the icon for when the battery is being charged. When the unit is turned off I got the icon for amount of battery life that floats around the screen.
    I have contacted Garmin and updated to the latest software version. No change in the battery status described above. The 530 series is at the end of manufacture support so assistance from Garmin will not happen.
    Other than the batttery icon not showing correctly the unit function as it should.
    Any suggestions on how to resolve this battery issue?
    Mark
    • 31265
    Re: Garmin 530 HCx
    foto's of the pcb near the charger socket would be a good start.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
      APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
      This started a few days ago and does this about every 8 hours
      After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
      The battery backup is about 3 or 4 years old
      Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
      06-02-2024, 02:30 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
