Burnt smell Macbook Pro 13' mid 2010
  • MrBalls
    • Jan 2016
    • Portugal
    Hello everyone.
    I started this thread in order to get some council on my macbook pro 13'.
    The problem started a few days ago when i booted the mac it started to get a burnt smell. I immediately stopped the machine from booting and went looking for the problem.
    Mac Specs:
    Macbook pro 13' mid 2010
    Intel Dual core 2.66GHz
    Model: MC375xx/A
    Motherboard: A1278
    I can assure you no liquids or dropped in the machine or anything harmful. The burning smell came from a electronic component shown in the following images.
    My ideia was at first identify which component it was, and replace it, although im not sure if the component burning was the cause or consequence of something else.
    Has you can see in the picture the component is too much burned to get an actual reading on the id. And i couldn't find any schematics online for the given motherboard which led me here to this forum.
    So with this thread i was looking for some council on identifying this burnt component or based on experience if this is a consequence of another damaged component and which approach should i take on the matter.
    Thanks in advance for any support
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Burnt smell Macbook Pro 13' mid 2010
    Its a diode
    see here: http://forums.macrumors.com/threads/...#post-15102073
    Follow the white rabbit.
    • MrBalls
      • Jan 2016
      • Portugal
      Thank you for the fast reply.
      When you say diode, you are referring to mousepads comment "C6603 = 100UF 20% 6.3V Tant Case-AL1 (Speaker Amp Logic)"
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Yes, cap, not diode, it was 10pm when i posted that... It was a the image in post 588 that got me to that thread.
        The position on the board makes more sense for a cap too.
        • mferna14
          Apple MacBook Pro A2338 820-02773-A AON Rail burnt
          by mferna14
          Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
          06-25-2025, 11:26 AM
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
          Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview
          Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
          10-22-2024, 02:37 AM
        • electomech-fixer
          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
          by electomech-fixer
          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
          09-15-2025, 01:42 AM
        • Flasman90
          Macbook Pro DFU Restore Issues
          by Flasman90
          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
          08-30-2025, 10:27 AM
