A1278 "Stagelighting" on screen + high freq whine
  • 850csi
    • Jan 2016
    • 23
    Hey all,
    Picked this up cheap intending to use it as a desktop (mid 2009 mb991ll/a) It works perfectly for that purpose, but I'm tempted to try to fix its lcd anyways. It is remarkable how fast these old things feel with El Capitan.
    The display has the so-called "stagelight" effect at bottom:
    Obviously far more noticeable with lighter colors.
    In addition, the lcd will sometimes "freeze" and get washed out with lines and other gibberish:
    The screen becomes unresponsive when this happens. When this occurs, some strong pressure to the lower right portion of the bezel and/or moving the display restores the image.
    In addition, at anything less than full brightness there's a quiet high-pitched [incredibly annoying!] "whine" that gets quieter as brightness is lowered.
    If I had to guess, two independent issues, one perhaps with the power board and the other with the LVDS cable or hinges? Thoughts welcome.
    • 31011
    Re: A1278 "Stagelighting" on screen + high freq whine
    led strip needs replacing.
    some are dead, the working ones are stressed by overcurrent.
    that may be causing the whine too.
    it may even have a damaged driver chip.
    • 850csi
      • Jan 2016
      • 23
      Thanks! So it needs a new display, then, and should be fine?
      With regard to the bolded, any way to check on this? Isn't the fact that physical manipulation of the screen resolves/affects the situation suggestive of there being nothing wrong on the logic board itself? Or are you referring to the [constant] "stagelighting" rather than the other issue? Sorry, n00b here.
        • 31011
        i was refering to the led driver,
        when they blow they usually have a hole in them!
        take the panel out and examine the small square chip near the led strip cable.
        • 850csi
          • Jan 2016
          • 23
          You're referring to it as shown in this picture, correct?
          Mine looks fine as far as I can tell...
          (really appreciate your help & patience)
            • 31011
            that looks o.k.
            i'm surprised it's there though,
            on most laptops it's on the display panel itself, not the mainboard.
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              first picture looks like a bad led , while second picture looks more like bad panel or bad lcd cable. if u can try another lcd cable and lcd.
              • 850csi
                • Jan 2016
                • 23
                that looks o.k.
                Yeah I figured there was something being lost in translation - I only knew this because of extensive googling, got that image from ifixit. Can't verify the accuracy myself.
                Thank you both for your help. We'll see... I'm tempted to try getting a replacement cable and see what happens but taking the screen apart to get at it is quite an ordeal. Was mostly trying to figure out if it's worth the effort - can I be reasonably confident my logic board is ok?
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  try with a dvi adapter and see if image is ok.
                  try also a pram reset and smc reset before change lvds cable as u have to unglue the glass (very noisy part)
                  also when u have that king of lines, try open close the lcd and see if problem still present or disappear. if disapper probably a bad lvds cable, if still present probably bad lcd.
                  check also temperature of component with hardware temperature monitor if they re ok (max 100°)
                  • 850csi
                    • Jan 2016
                    • 23
                    Have been using it as a desktop and it works like a champ
                    PRAM/SMC didn't resolve anything
                    When I have the screen cut out like in the 2nd image, some pressure to the bezel or moving the display sometimes resolves it. The spotlights are there ever-presently, though.
                    Will check on temps.
                    • 850csi
                      • Jan 2016
                      • 23
                      Temps look good. This was taken with the screen fading in and out. Sorry forgot to switch to Celsius first.
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • CroBUTKO91
                        can you damage screen panel with high voltage
                        by CroBUTKO91
                        hi i have philips led tv i had vertical lines all over the screen so i was testing voltages on board connected directly to screen below t-con
                        i accidently shorted two caps just above flat cables going to screen 20v and 2v and the 2/3 of the left side of the screen has gone white but vertical lines are still there i still have all the voltages on caps nothing is shorted so im just wondering is it posible i damaged the screen (burned pixels) when i shorted caps ot its posible the t-con board got damaged, thank you
                        07-25-2022, 06:31 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
