Identifying this component
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Good day guys. Could you please help me identify this mosfet? All I have are these markings, A2719 M 001. I've search the net and it points me to a NEC PA2719GR. I don't know if this is the same. I attached picture and datasheet of NEC mosfet. Thanks everybody!
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Re: Identifying this component
    Umm guys.. how do you attach image here. I've been out for a while. I don't see any options to do that in advance mode.
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      Ok. I didn't read what was going on for this site. Sorry for being stupid. I hope everything goes well for the site. here are the images.
      • kazia
        • May 2015
        • 145
        • indonesia
        I think it's the same mosfet.
        http://www.aliexpress.com/item/15Pcs...451318411_6449
          • 30979
          http://elcodis.com/parts/6168628/upa2719.html
          • lezsimply
            The Wanderer
            • 645
            • Philippines
            Thanks guys. Yes its the same. So I just need to find replacement parts here. By the way, laptop problem has no power. 19v from charger to dc jack. but on the other end of the pin which is connected to motherboard, voltage measured 1.8-2.1v fluctuating. Which must be 19v too. I found out this mosfet is heating up. Other side of mosfet is good I think. Thanks again
            • lezsimply
              The Wanderer
              • 645
              • Philippines
              Could you please help me determine if this AO4413 p-channel fet is compatible with a2719? Here are the links. thanks
              http://pdf1.alldatasheet.com/datashe...MD/AO4413.html
              http://pdf1.alldatasheet.com/datashe...UPA2719GR.html
              • subroto
                • Oct 2015
                • 230
                • Bangladesh
                It's just a P-channel power MOSFET. Just replacing with another P-channel power MOSFET of charging line from another board. It will work fine.
                • lezsimply
                  The Wanderer
                  • 645
                  • Philippines
                  I thought some p-channel mosfets have special characteristics. I have doubts replacing component when I don't have the schematic for laptop motherboard. This one is a Fujitsu fmv-biblo loox g/m2. I will this and see if it works ok. Thanks man.
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • madjid911
                    identifying a mosfet for asus laptop
                    by madjid911
                    HI, I discovered a mosfet in continuity, and grounded the motherboard. I would like to replace it to be able to repair the motherboard of my asus pc. I am not a big expert, can you tell me what is this mosfet?I can't find it on the internet.
                    Can you help me find the datasheet and maybe tell me which mosfet I can replace? I have macbook a1466 1708 1278 donor motherboards.
                    THANKS...
                    08-08-2023, 01:57 PM
                  • boardbread
                    Identifying MOSFET "03 GUB 7X1V03" or "02 GUA 6X4H06"
                    by boardbread
                    Hello! I have these MOSFETs used on a desktop motherboard, the name of the motherboard will not be helpful, because it is quite rare and doesn't have schematics. They are used in a power rail and have very unusual metallic package, I've never seen anything like this. Could you help me identifying these, or at least identify their package?
                    12-24-2024, 10:26 AM
                  • kingis85
                    Asus rog flow gz301v mosfet ic identifying
                    by kingis85
                    Here i have asus rog flow, super powerfull and expensive tablet. The problem is that it only works with a battery. The owner had it plugged on and his dog wanted to put his teeth on the usb-c plug and well.....
                    So after that it is not charging with a new asus official charger. I opened and tried to find something burned with microscope but everything looks good. I did not found any short. I did see that it does not try to take any power with usb meter, so the 5v line must be open somewhere. This board is really hard to make any sense because i can not find any kind of data sheet or info....
                    11-20-2023, 05:50 AM
                  • Nooy
                    VGA MOSfet permanently shorted and loss of MOSfet pad
                    by Nooy
                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                    02-14-2024, 02:26 AM
