Is GD25Q64BSIG compatible with W25Q64FVSIG?
  • orientalsniper
    • Apr 2013
    • 461
    GD25Q64BSIG is broken and I only have W25Q64FVSIG
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Is GD25Q64BSIG compatible with W25Q64FVSIG?
    you can flash it
    is compatible
    • orientalsniper
      • Apr 2013
      • 461
      Are you sure? Have you replaced it? I tried it and it didn't work. I just wanna make sure it's not the BIOS chip that is the one having problem.
      • the-sky-blue
        • Dec 2013
        • 48
        • salfeet
        hello friend , just sold it again
        • ridamouh159
          • Nov 2014
          • 365
          • maroc
          i m sure
          • dicky96
            Lenovo USB 3 Port Broken socket - compatible types?
            by dicky96
            Hi guys
            I have a broken USB 3.0 Socket. I've removed the old one
            If you look at the pictures on this listing, mine is the type shown as 'old version', but this seller only has 'new version' available to buy and I can't find anyone else selling the old version
            https://www.aliexpress.com/item/1005...46346716%22%7D
            Are these actually compatible?...
            09-18-2021, 05:50 AM
          • chth96
            Is it possible bridging tiny broken trace
            by chth96
            When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
            cutting tiny trace.
            This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
            Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
            But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
            12-03-2022, 11:32 PM
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
          • ArchangelGabriel
            Aorus 17G YD laptop, broken display, could not switch to external monitor
            by ArchangelGabriel
            Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
            11-23-2023, 03:55 AM
          • corrize
            Resonator - quartz broken - how to find the same (same frequency) ?
            by corrize
            Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
            I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
            I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
            I'm searching another one for compare…
            Do you have an idea or another way for find the frequency of this resonator please ?
            (I did not found the manufacturer of this component ? And I did not found the...
            03-27-2025, 09:20 PM
