tps51225 burns hot
  • rookieme
    • Oct 2014
    • 399
    • Greece
    tps51225 burns hot
    I have a NEWTON_BR_HPC motherboard that has no power issue.
    I can't find the schematic but tps51225 burn hot.
    I replaced it but I have the same result.
    I couldn't find any shorts.
    Any suggetions?
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: tps51225 burns hot
    See the data PDF for the TPS51225, It has two LDO regulators that are always on, 3.3v and 5v. Do they have the correct voltage output?
    • rookieme
      • Oct 2014
      • 399
      • Greece
      The two LDO are pin 3 and 13.
      The issue is that can I power it and do the measures or will it be further be damaged by the heat produced?
      • rievax_60
        • May 2012
        • 897
        • australia
        There is a risk. Just don't leave it on for too long or check for shorts on both rails.
        • bushie
          • Dec 2013
          • 57
          • Romania
          Change the ITE.
          • rookieme
            • Oct 2014
            • 399
            • Greece
            No shorts at the rails.
            Well my second thought was the ITE, could it be the cause?
            I maybe remove it to see without it.
