tps51225 burns hot
  • rookieme
    • Oct 2014
    • 396
    • Greece
    tps51225 burns hot
    I have a NEWTON_BR_HPC motherboard that has no power issue.
    I can't find the schematic but tps51225 burn hot.
    I replaced it but I have the same result.
    I couldn't find any shorts.
    Any suggetions?
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: tps51225 burns hot
    See the data PDF for the TPS51225, It has two LDO regulators that are always on, 3.3v and 5v. Do they have the correct voltage output?
    • rookieme
      • Oct 2014
      • 396
      • Greece
      The two LDO are pin 3 and 13.
      The issue is that can I power it and do the measures or will it be further be damaged by the heat produced?
      • rievax_60
        • May 2012
        • 897
        • australia
        There is a risk. Just don't leave it on for too long or check for shorts on both rails.
        • bushie
          • Dec 2013
          • 57
          Change the ITE.
          • rookieme
            • Oct 2014
            • 396
            • Greece
            No shorts at the rails.
            Well my second thought was the ITE, could it be the cause?
            I maybe remove it to see without it.
              by Vesko356
              08-11-2023, 03:27 AM
            • corrize
              Where to find a very small fpc connector 0.3mm between 2 pins ?
              by corrize
              Hello, I search this connector (oxydated).
              It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
              I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
              I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
              Do you know how to find this connector please ? What is the exact name for find it ?
              08-06-2024, 05:25 PM
              Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
              This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
              Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
              07-07-2024, 02:34 PM
            • temyth
              Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
              by temyth
              Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
              The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
              01-07-2024, 04:50 PM
            • PizzaMan
              Macbook Air A2681 logic board, find this part
              by PizzaMan
              I am trying to find this part on the logic board. See pictures below. It might be CR812, not sure. Any help would be appreciated. And where could I find the part?
              05-24-2025, 12:34 PM
