Hp g62
  • senchire
    • Dec 2012
    • 190
    • Bosnia
    Hp g62
    Hello guys, this one is making me some troubles now.
    Came in with "not starting" case. I've plugged it in started and voila it starts, stays on for about 1-2 mins, then auto turn off (no overheat), afterwards it wont start for quite some time only blinks on all leds.
    If you discharge it (1min holding power button without power cord), nothing happens, but if I leave it for more then 40mins off, it will repeat the process.
    Didn't find anything similar, could it be the bios or the gpu perhaps?
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: Hp g62
    I don't think s the bios, you can try with other cpu and see.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • senchire
      • Dec 2012
      • 190
      • Bosnia
      Re: Hp g62
      Damn work had no time to check it out. Did today, now I get to install everything and boot up to windows but then again it I can install the HD4200 in it, it even installs the HD5400 but it won't switch to it, stays on the HD4200, smells like a gpu fault.
      I've read on the interest a lot about this one, and mostly people refer to the drivers, I've tried like 10 versions and get different outputs namely sometimes it won't install the
      HD5400 and sometimes will, but I can never use it, I see it only installed.
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • 24gsm
        MacBook Pro A1708 install macos fail
        by 24gsm
        hi to all
        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
        after enter to recovery and format hdd 1to .
        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
        can help please
        Serial Number: FVFXP0U0HV2J
        Config Code: HV2J
        Find My Mac: OFF
        04-16-2025, 03:57 AM
      • duwane
        A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
        by duwane
        Hi All.
        Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
        The issue:
        Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
        10-26-2022, 07:02 AM
      • TrumanHW
        MacOS: R|W Programmers like CH341x BINs..?
        by TrumanHW
        For years I tried figuring out how to R|W BINs from my CH341x programmer.
        From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
        I'd expect many here figured it out (easily), but in case not ...
        It's one of the few forms of "how-to" remuneration I can GIVE BACK.
        This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
        This may be the easiest means to copy-paste:
        Code:
        SERIAL -to- USB - CH341 ROM (MacOS):
        Install xcode:				xcode-select --install
        Relocate
        04-08-2022, 02:33 PM
      • sajidmirza
        A1990 cant install OS after SSD nand repalced
        by sajidmirza
        Got A1990 with ssd nand ic shorted.Repalced all the nand ic from same donor board.Restored in apple configurator successfuly and booted to recovery.Its high siera recovery.But when i try to insatll OS from internet recovery it gives error "Recovery server could not be contacted".tried at different places thinking of low internet but still getting same error.Tried date adjustment from terminal also.
        i have heard that we cant install OS from high siera recovery at the moment.Is it true.If yes how to update recovery to latest one.tried to restore several times from...
        07-06-2023, 07:53 AM
