LA-791 not charge
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    LA-791 not charge
    Hello everyone
    i m working from 2days with this P.bell that don t charge.
    This bord is Q5WVH LA-7912P Rev 1.0 used too in Acer e-series.
    I measured :
    PQ9 pin5678 have 19v pin1234 no voltage
    PQ10 , PQ11 no voltage
    CHANGED pq9 , pq10, pq11 the same problem.
    THE PROBLEM IS MISSING 3V (acok PU4 not have 3v no 3.3v on bios chip no 3.3v on pu5)
    Any suggestion???
  • LP_tekh
    • Oct 2015
    • 95
    • Laos
    Re: LA-791 not charge
    You can share the schematic so the other can see it and share their though.
    • p1muserfan
      • Apr 2014
      • 184
      Here
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        Seem B+ short to ground.
        -check resistance B+ to ground
        -check VCC voltage
        -Voltage acdet should be ±2.6v
        • gcomputers
          • Apr 2013
          • 509
          • Albania
          -check VCC voltage
          Thanks Meritosari
          Yes B+ (measured from pd6 pin2) is SHORTED with ground voltage 09.2mv 51,8ohms
          pin1 pin3 of PD6 19v stable
          VCC voltage (measured from PU4 pin20) is 19v stable
          ACDET is 1.38v
          What can i do ?????
          • angel-boy
            • 550
            • Romania
            insert adapter or insert 1v-2v between pd6 pin2 to ground and check parts that will heat up. quickly remove if smoke will come up
            with this method, you will quickly find the shorted component.
            • LP_tekh
              • Oct 2015
              • 95
              • Laos
              Check pq11 if is bad, if is bad, remove it and check it again off the board same way like the other shorted components.
              • gcomputers
                • Apr 2013
                • 509
                • Albania
                tested it, inserted with power supply lab 1v 7a and PD1 it heats up a little removed it tested with diode mode are ok , but the same problem do not charge.
                • gcomputers
                  • Apr 2013
                  • 509
                  • Albania
                  all line from PQ11 pin5678 from PQ12 pin5678 are shorted with ground .
                  Replaced PQ11 the same problem removed PQ12 to test it no change the short continue.
                  Yesterday received another acer with the same board (la-791) with identical problem not charge , same short .
                  What can i do any suggestion ?
                  • LP_tekh
                    • Oct 2015
                    • 95
                    • Laos
                    May be there is no communication between BQ24725ARGRR and KBC 128pin, so either BQ or 128pin is bad, if all components connected to B+ rail are good.
                    I know is a lot of work to do, but you have to try to find out.
                    • dj_ricoh
                      • 2073
                      Diode mode?
                      Ohm mode only . if it shows value on both sides then its bad. It leaks.
                      In order to find that shorth, guessing it's a cap you need to pass 2.5v on psu lab with 1-2 amps.
                      I repair 2 HP's and 2 Sony vaio with almost 4 v and 1.5amps.
                      It heated those caps so I can find them and voila they all work.
                      • gcomputers
                        • Apr 2013
                        • 509
                        • Albania
                        Thanks Dj ricoh , i checked the diode removed from board , i will check with your metod today. Thanks anyway
                        • meritosari
                          • Oct 2010
                          • 774
                          • Indonesia
                          try remove one by one PL that related with B+, then measure resistance after desolder one PL. PL3 PL5 PL8 and so on
                          • wws911
                            • Apr 2020
                            • 10
                            • South Africa
                            Hi guys . i have the Same Problem .
                            1. i charged the batt with a bench power supply.
                            2. when i plug the charger in then put the batt in the charger goes in to protection
                            3. so i plug the charger in then plug the battery in then in windows i get plugged in and charging but its not.
                            where should i start checking as im very new and learning .. appreciate and and all guidance
                            thanks in advance
                            • mon2
                              • Dec 2019
                              • 14181
                              Same logic board and schematic?
                              Power down / remove battery.
                              Meter in resistance mode.
                              Check and post the resistance if each mosfet starting fr the dcin jack.
                              You will have mosfets in this area.
                              What are the values for each mosfet for:
                              Source & drain
                              Source & gate
                              Gate & drain
                              • vannix
                                • Mar 2018
                                • 74
                                • Italy
                                i just repaired 2 boards la-7912p with b+ shorted to ground, and in both the problem was a ceramic capacitor 25v 4,7uf.
                                in this case i suggest to replace all 4.7U_0805_25V that you can find in schematic, because after a while also the others could short to gnd, as often happens in many boards that use similar capacitors.
                                • ipatch
                                  troubleshooting microsoft surface pro 4 no power no led charge light
                                  by ipatch
                                  hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                  10-05-2023, 11:59 AM
                                • ruletero
                                  Acer a515-43 low battery charge voltage
                                  by ruletero
                                  Hi
                                  Acer A515-43
                                  LA-H801P
                                  Fail: Does not charge battery, has low voltaje on connector.
                                  Laptop didn't want to turn on, only charge led blinked.
                                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                  10-24-2022, 02:31 PM
                                • Klevjetack
                                  Charge a L19D3PDA battery externally from the laptop
                                  by Klevjetack
                                  Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                  03-05-2024, 07:26 AM
                                • razenxd
                                  How can I charge that battery pack?
                                  by razenxd
                                  it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                  At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                  Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                  Now, I have noticed a few things.
                                  The "dead" battery, while connected to charger and NOT Charging will...
                                  12-05-2024, 06:11 AM
                                • Elektronror
                                  Asus GL702VS No charge, unstable GPU power
                                  by Elektronror
                                  First post here, second if you count the introduction thread, so don't hesitate to tell me if I'm doing something wrong.
                                  Bought a used Asus GL702VS which had been sitting for a while so it arrived with a dead battery. Plugging in the charger it came back to life and I didn't notice any problems with the computer. I also used it running on battery for 1-2 hours. I then played around with undervolting the CPU with the charger connected when a 10uF MLCC shorted AC_BAT_SYS. After removing the short, battery won't charge and the GPU has power limitations. I suspect that these are 2 different...
                                  02-05-2021, 10:39 AM
