Dell Inspiron N5010 15R No Power
  • ITSYSTEMSALBANIA
    • Mar 2015
    • 37
    • Albania
    Hi
    I have a Dell Inspiron N5010 15R with no power when i press power button the light in power button came on but fan doesnt spin.I measured 3.3v at the power button and 3.3v at pin 7 and 5v at pin 24 of PU4601.Checking the board i see that PU4901 gets hot.Please help me to trubleshoot this board.
  • p1muserfan
    • Apr 2014
    • 184
    Re: Dell Inspiron N5010 15R No Power
    Originally posted by ITSYSTEMSALBANIA
    Hi
    Measure voltage at PL4602 and pin 7 of PU4901 to make sure its not short to ground.
    • ITSYSTEMSALBANIA
      • Mar 2015
      • 37
      • Albania
      Hi
      Thank you for your time at PL4602 i measure 5.1V and pin 7 of PU4901 is not shorted to ground investigating on the board i measured PU4905 and PL4901 shorted to ground.Please tell me what to do.
      • p1muserfan
        • Apr 2014
        • 184
        PL4901 is showing short because PU4905 is showing short. If you remove 4905, 4901 should no longer be short and 4905 is your problem. Try it
        • LimesKey
          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
          by LimesKey
          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
          10-17-2025, 05:33 PM
        • zlr8r
          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
          by zlr8r
          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
          Ill try and give as much info as I can.
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          When I received this , it would only flicker on the KB backlight for a second, then off and on.
          Then it started getting weirder!
          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
          12-12-2023, 09:31 PM
        • Tomylee
          Dell Inspiron 15 3511 – Won’t power on after plugging in, one chip gets extremely hot
          by Tomylee
          I have a Dell Inspiron 15 3511 that stopped turning on after my friend plugged in the power adapter.
          Here’s what I’ve checked so far:
          No reaction when pressing the power button (no LEDs, no fan).
          The power adapter works fine (tested).
          One chip gets extremely hot as soon as I plug in the charger.
          The capacitors around that area are not shorted.
          I’m attaching photos of the board to show the issue.
          Based on this, what kind of fault or defective component could be related to this overheating?...
          10-19-2025, 12:24 PM
        • madura2010
          Dell inspiron 3168 (15299-2) no power
          by madura2010
          Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
          But after removing battery, worked perfectly.
          next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
          But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
          Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting...
          01-28-2024, 09:10 PM
