Macbook mid-2012 Keyboard issue
  • xalu
    • Mar 2015
    • 37
    I recently fixed a macbook pro 15, however, I am having some issues figuring out whats wrong with the keyboard.
    I replaced the one it had in there since it was sticky and wasnt working. It was working with some keys, but only on startup.
    Now with the new keyboard its doing the same thing. Only works on startup then it wont do anything. On startup if I press the caps lock it quickly goes off. (light on then off)
    It seems like something is shorting it out. Anyone have any advice or experience something like this before?
    (Side note: the trackpad isnt connected since I am waiting on a replacement).
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook mid-2012 Keyboard issue
    test impedance of each pin for keyboard.
    • xalu
      • Mar 2015
      • 37
      I just got it working. I attached a separate trackpad(from a 13" mbp) and it works. I guess it was just because no trackpad was attached. Is that normal?
      Once I attached it seems to be working fine.
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        never experienced that. glad u fixed it.... but let's wait some days to be sure fproblem is 100% fixed
        • hexdiy
          • Oct 2015
          • 6
          • Belgium
          I hink the internal USB hub is contained within the trackpad. That may explain a lot.
          • ugamazing
            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
            by ugamazing
            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
            04-10-2024, 08:06 AM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • playit
            ps/2 port keyboard dead ? p5ql pro / ethernet cable light
            by playit
            my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
            my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
            few years back ps2 mouse stopped working, but ps2...
            12-23-2024, 06:05 AM
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
            HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
            09-06-2024, 06:21 AM
