Macbook Pro A1278 wont power up
  • angel-boy
    • 550
    - when i press power button , power led light about 1 second and off.
    - no sound , no image, the fan spining few seconds
    any help ?
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Macbook Pro A1278 wont power up
    i have one with same exact syntom. reballed chipset and smc and reprogrammed bios: same result.
    • crowntoy99
      • Oct 2012
      • 264
      • india
      try Re Flash bios
      try also bios chip track ..
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        angel boy can u post pin bios voltage ?
        on mine i have only the 3.3 voltage at pin 1-3-8 so i thing my nvidia chipset is dead...
        • angel-boy
          • 550
          tell you tomorrow .
          • angel-boy
            • 550
            I talked to a friend and told me possible defective processor or may require reballing
            • angel-boy
              • 550
              i dont have charger , the battery is down.
              what did you think about my friend opinion ? cpu ?
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                in my macbook there is a p8600 that get very hot as a cpu normally, so it could be possible.
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  this week end il get the board with reballed cpu. we'll see if it was right that problem was cpu :p
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    macbook with cpu reballed..... still power on and fan spin for 1 -2 seonds then power off.... so it's not a cpu problem...
                    • SarcasticOP
                      General question about MacBook power rails for repair.
                      by SarcasticOP
                      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                      • PPBUS_G3H (12.6V-12.8V)
                        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                      • PP3V42_G3H (3.42V)
                        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                      • PPVRTC_G3H (3.3V)
                        • This
                      12-12-2024, 05:50 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • Adogabriel100
                      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                      by Adogabriel100
                      Hey! This is a A1278 macbook 2011.
                      Problem: Not turning on / No green light
                      Im using by3200s charger.
                      Voltajes:
                      PPBUS_G3H = 12.26v
                      SMC_RESET_L = 3.3v
                      PP3V42_G3H = 3.42v
                      U7000 =
                      Pin 1 CHGR_AGATE = 0v
                      Pin 2 CHRG_DCIN = 19v
                      Pin 3 CHRG_ACIN = 4.6v
                      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                      Pin 12 PP3V42_G3H = 3.42v
                      Pin 13 CHRG_RST_L = 3.3V
                      Pin 14 SMC_BC_ACOK = 0.8V
                      Pin 19 PP5V1_CHRG_VDD = 5.05V
                      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                      04-01-2024, 01:02 PM
