Toshiba L310 not powering on,
  • kazia
    • May 2015
    • 145
    • indonesia
    Got Toshiba L310 on my table, it's not powering on,
    +5v and +3v ok, probably bios error what.
    attached schematic and bios file.
    and fix this bios, just wanna flash that bios first.
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Toshiba L310 not powering on,
    What makes you think is a bios problem?
    • kazia
      • May 2015
      • 145
      • indonesia
      it's just my suggestion, coz I'm not an expert.
      could you help me friend.
      • kazia
        • May 2015
        • 145
        • indonesia
        any one help me here...
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          check nbswon# and rsmrst# signal before and after pressing power button
          • kazia
            • May 2015
            • 145
            • indonesia
            nbswon# is good, but no signal/volt on rsmrst#
            what should I do next..
            • dj_ricoh
              • 2073
              • uk
              Advice.
              When some one ask you for a pin whats there . You say voltage value. Or scope pictures.
              You don't say its good .
              And on top of that you said your not expert. I'm not expert.
              But when i want help i say what i found what i can find and what i can i do.
              So. Voltages ok?
              Find every coil on the board and check for short with ground reference.
              Remove cpu it will miss guide you.
              • samanthban
                • Feb 2014
                • 253
                • Sri lanka
                Originally posted by dj_ricoh
                Advice.
                learning point
                sigpic
                • meritosari
                  • Oct 2010
                  • 774
                  • Indonesia
                  try reflash bios, might be this can help:
                  • kazia
                    • May 2015
                    • 145
                    • indonesia
                    Advice.
                    So. Voltages ok?
                    Thanks for your advice my friend,
                    • kazia
                      • May 2015
                      • 145
                      • indonesia
                      it's 1 mb bios, not 2 mb
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
                      • YvD-Electronics
                        Request BIOS files to flash Toshiba C55-A-1TX laptop
                        by YvD-Electronics
                        I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
                        Why I am pretty sure I need this to repair?
                        1) Power supplies seem OK.
                        2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
                        3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
                        4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
                        08-09-2024, 10:05 PM
