Thanx in advance friends
i need equivalents of AON7403 Mosfet
Re: i need equivalents of AON7403 Mosfet
stop asking for interchange for mosfet. ANY p-channel mosfet with adequate current will be good -
maybe, but it's not the average package!Attached FilesComment
why? that package is using any newest laptop. i think every one with ddr3Comment
This package - DFN3x3 / DFN3x3EP - is around for some time now...
A&O uses it among several other brands: Advanced Power, SeCoS, CYStech, ...
If searching for an equivalent these other brands might help.Comment
well , simple chek , for compatible mosfet ,,, you can do it . simple chek some reference values does one must be more or less exact with a max diference of 10%
chek for inrush total currrent , max voltage , and peak current , does values must be more accurate possible
so chek for all Pchannel you find for the package type and it does values are insyde the parameter value , then you're up to go . i do it all the time and never had problems with that , if i dont have in stock (and i do have tons of components in stock , but impossible to have all )Comment
by dreico33Hellow guys,
I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
Thank you very much. -
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
by NooyHello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet... -
by redbaron1007I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...1 Photo -
Hey guys,
i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
Now i thought something... - Loading...
