CQ61 turn on and off ..not finding culprit here , help !
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Hey guys ,
    Well got this one in the bench , and its giving me a bit of headhack ..
    symptom : turn on then off after 1 sec . it happen to turn on once or twice with no problem , but still always doing the same now , on and off.
    Cheked all coils to GNG - OK
    Cheked S3 and S5 to KBC - OK (even like this replaced ENE D2,the same )
    Flashed bios - OK
    Cheked main starter signal , RSMRST - OK
    PLTRST - not beeing feeded by Southbridge as it should .. this could be a problem , but not sure south bridge fault .
    Cheked main lines once S0 is deploy , all voltages goes ok on coils.
    weird thing is not having PLTRST and im getting all voltages during this second the machine is ON .
    Battery does charge normally .
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: CQ61 turn on and off ..not finding culprit here , help !
    maybe something on discharge i dont know , if she stay a bit of time without power , once i press on , she will turn on and stay on ,, after few attemps goes to same symptom , on and off .. kind weird
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      weird thing also , everytime machine do that if i give a bit of heat on the clock gen ic , it wil turn on no problem , gives image etc all good
      so relaced clock gen and crystal ... but does the same ... only giving a bit of heat it will work
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        it must be cold joint... same symptoms i had with famous nvidia 6150 or so if i remember correctly...
        after reflow, it worked fine
        i understand its other platform, but by the symptoms problems sound like cold joint
        Im Back... sort of...
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          agree to ala_borbe
          • PlusCom
            • May 2013
            • 50
            • Greece
            Number of your southbridge?
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              IBM . but alltough the clock gen is far far away from SB , and when i mean saying giving a bit of heat ,its just a bit of heat , like 1 or 2 second , can be a could joint , but if it is its around the small smd components around the clock gen .
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                put some flux all around, reflow whole area around and test again
                • pajdek
                  Lenovo Y700-17ISK turn on and off
                  by pajdek
                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                  09-20-2023, 02:49 AM
                • im_trying
                  MSI GF65 Thin doesn't turn on, shorted on dc-in, how to find the culprit?
                  by im_trying
                  Hi, thanks for helping.
                  The motherboard is from a gaming laptop, msi gf65 thin 10ue, 16W21/11S.
                  For starters, it doesn't power on. I measured a "short" on the second DC-IN mosfet, right around the charging port but I don't know how to find the component that's shorting it.
                  I already tried checking the mosfet for internal shortage (by desoldering and measuring) but no short. The drain on the motherboard is the one that's shorted, next to the gate (that's not shorted).
                  The photo below shows this better than words.
                  Thanks for anyone...
                  05-12-2025, 04:16 AM
                • RdeveLabs
                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                  by RdeveLabs
                  To all the members here...
                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                  05-05-2025, 04:59 AM
                • robante15
                  Acer Aspire 4520 won't turn on after reboot
                  by robante15
                  Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                  It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                  The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                  If I remove the...
                  04-06-2024, 06:50 PM
                • masoksian
                  Dell latitude e7470 not turn on .power buton on off and Run Power problem
                  by masoksian
                  I am dealing with the problem of turning on and off my Dell e7470 notebook.
                  The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                  The system does not turn on, there is no post.
                  I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                  The problem continues in the same way.
                  I tried to turn on the Fn key, nothing came to the screen....
                  02-15-2025, 12:08 PM
