Ultrasonic cleaning fluid for Cell Phones
  • Ltank
    • Jun 2013
    • 776
    My wife 's expensive Cell Phone got moisture damage some how.
    I bought a 2.5 liter Ultrasonic Cleaner. Most cleaning fluids online are expensive especially if you add shipping. My question for you guys is.
    What does a good DIY Ultrasonic Cleaning Fluid consist of?
    What Ratio of what are needed? Any other info is appreciated.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Ultrasonic cleaning fluid for Cell Phones
    now it is worthless for u. board must be cleaned with isoprophyl to 1-3 days max. otherwise the corosion eat your board
    • mmartell
      • Oct 2013
      • 3189
      Remove the board and have a good close look at it to see what damage has been done.
      • tmhobadcap
        Lithium ion cell voltage not going up after 3.8V
        by tmhobadcap
        I got a chromebook with battery problem. It was charging when plugged in. But the indicator just showed that the battery was below 10% no matter how long it was plugged in. I took the battery pack out. There are two cells in series. Each cell had a voltage of about 3.7V. I charged one of them with a lithium cell charger. I can see current going into the cell at about 500mA. After several hours, the voltage was just about 3.8V. I charged it again manually by connecting 4.2V to it from a power supply and set the maximum current to 500mA. I can see about 100mA going into the cell. But the voltage...
        02-03-2025, 01:30 PM
      • Evets
        Ultrasonic cleaning
        by Evets
        I've just bought an ultrasonic cleaner and wonder what the fluid of choice is? Isopropyl alcohol was my first thought.
        07-31-2024, 11:33 AM
      • rumi409
        LG OLED C1 Pixel Cleaning Made Picture Worse
        by rumi409
        ​​​​​​ Hi,
        I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
        11-15-2024, 01:09 AM
      • itsthatidiotagain
        CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
        by itsthatidiotagain
        CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
        There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
        I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
        A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
        06-23-2025, 03:22 AM
      • howardc64
        Macbook Dust-Gate Preventive Cleaning
        by howardc64
        Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
        Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
        https://www.ifixit.com/Guide/MacBook...leaning/177920
        10-09-2024, 10:10 AM
