Macbook Pro 15" Mid 2010 No Power
  • crdz66
    • Nov 2012
    • 242
    Hello Friends.
    I have a problem with a Macbook pro with no power at all.
    This unit don't have a orange and green light indicator on magsafe power supply connector.
    I check the voltage on charger and that give me 16.xx volts and the same on the pins back power jack.
    There is a fuse or capacitor (i don't which one is) and one side give me 16.xxvolts but 0 on the another one.
    The continuity and ohms reading is unstable.
    Any Ideas??
  • Mario
    • Sep 2007
    • 64
    Re: Macbook Pro 15" Mid 2010 No Power
    Might be graphics chip. Try a reflow or reball.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      what have graphics chip with charger?
      • crdz66
        • Nov 2012
        • 242
        OK. Going to try reflow because can't do the reball
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          fck reflow. Dont try every stupid advice
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            no green/orange light when 16volt are present:
            1) no g3hot 3.42 volt
            2) bad magsafe board
            3) bad u7000 chip (short something)
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              i have too problem with geohot 3.42V, fuse in front of it was broke, so try to measure it
              and NEVER reflow if u really dont know the problem. GPU, NB or SB just heat up to 100c. if ic is good it will work
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                3.42 line doesnt have a fuse. probably it's a 47omh 0805 resistor.
                if it blow there's a short on the 3.42 volt rail
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  yes u have right it was resistor. it blown because of aluminium covet touch some capacitor on 3.42V line
                  • crdz66
                    • Nov 2012
                    • 242
                    Update.
                    Finally I find the problem with why the power light is not turn on.
                    Somebody open this laptop before and the connector between the power jack board and logic board was bend. Means the 5 pins connector (female) was bend on logic board. 2 legs make good contact only.
                    But, Still the laptop doesn't turn on.
                    My concern is If I have the right power supply.
                    I'm used a 16.5v 3.65a 60w.
                    This is from website:
                    Product Features
                    Device Supported: Notebook
                    Input Voltage: 110 V AC, 220 V AC
                    Output Voltage: 18.5 V DC
                    Maximum Output Power: 85 W
                    Maximum Output Current: 4.60 A
                    Compatibility: Apple MacBook Pro Notebooks:
                    A1172 A1221 A1222 A1226 A1290 A1260 A1229 A1150 A1286 661-3994 ADP-90UB
                    So, What fo you think guys.
                    I'm used the wrong one.???
                    • crdz66
                      • Nov 2012
                      • 242
                      Update.
                      I don't know how but after couple minutes this laptop start working.
                      Was the reflow?
                      Start with grey colors and after turn off and turn on, now is working.
                      Thanks to everybody.
                      • SarcasticOP
                        General question about MacBook power rails for repair.
                        by SarcasticOP
                        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                        • PPBUS_G3H (12.6V-12.8V)
                          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                        • PP3V42_G3H (3.42V)
                          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                        • PPVRTC_G3H (3.3V)
                          • This
                        12-12-2024, 05:50 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
