dell inspiron n5040 no power
  • knightdad
    • Apr 2015
    • 54
    • usa
    hey all need help with this one
    i have got no power to leds
    i open it up it has an dv15 cp uma mb 10263-1 48.4ip01.011 motherboard
    i get volts at f5401 24 volt fuse
    i get NONE at f5501 it should be 6v
    any help please
    thanks brandon
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    Re: dell inspiron n5040 no power
    check v on battery connector
    • knightdad
      • Apr 2015
      • 54
      • usa
      i get volts on battery get when plug the chager in led comes up the one for chagaring
      no power led
      • kestovious
        • Jun 2014
        • united states
        no one knows ok
        • LimesKey
          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
          by LimesKey
          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
          10-17-2025, 05:33 PM
        • zlr8r
          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
          by zlr8r
          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
          Ill try and give as much info as I can.
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          When I received this , it would only flicker on the KB backlight for a second, then off and on.
          Then it started getting weirder!
          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
          12-12-2023, 09:31 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Tomylee
          Dell Inspiron 15 3511 – Won’t power on after plugging in, one chip gets extremely hot
          by Tomylee
          I have a Dell Inspiron 15 3511 that stopped turning on after my friend plugged in the power adapter.
          Here’s what I’ve checked so far:
          No reaction when pressing the power button (no LEDs, no fan).
          The power adapter works fine (tested).
          One chip gets extremely hot as soon as I plug in the charger.
          The capacitors around that area are not shorted.
          I’m attaching photos of the board to show the issue.
          Based on this, what kind of fault or defective component could be related to this overheating?...
          10-19-2025, 12:24 PM
        • madura2010
          Dell inspiron 3168 (15299-2) no power
          by madura2010
          Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
          But after removing battery, worked perfectly.
          next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
          But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
          Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting...
          01-28-2024, 09:10 PM
