Hp g72
  • rookieme
    • Oct 2014
    • 399
    • Greece
    Hp g72
    The first problem was vga issue - known problem [black screen when windows started].
    After reballing, the second vga couldn't be recognized any more.
    Also replaced the chip but same problem remained.
    I have to mention that as windows was a clean factory setup with no other problem, after the repair effort I received a message that it is not original windows copy.
    Could it be bios related?
    If not what can I check?
    The part number is 615848-001
    I also own a HP dv6-6000 that also cannot recognize the second GPU [eGPU] and it is not s/w related, nor video chipset related.
    Any suggetion what to check is welcomed as I have 2 of the same problem.
    I'm not sure if I have the right schematic
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: Hp g72
    Maybe you can flash the bios chip and see what it does, and from the message about winsows i think its a software issue.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • rookieme
      • Oct 2014
      • 399
      • Greece
      Re: Hp g72
      It is not a software issue as windows detected the hardware change [it cannot detect the eGPU] and guess that it is a different hardware.
      Ok I'll give it a try with reflashing BIOS.
      Any more advices are welcome.
      • rookieme
        • Oct 2014
        • 399
        • Greece
        Re: Hp g72
        BIOS reprogram didn't help.
        It seems that somehow that GPU is not connected to the rest of the system.
        • Life Goes On
          • May 2014
          • 264
          • Curacao
          Re: Hp g72
          you can try to reflow it, maybe some balls don't make a good connection.
          • lebana
            • Jan 2015
            • 81
            • sudy
            Re: Hp g72
            thank u
            • fyaagoub
              • 269
              • maroc
              Re: Hp g72
              thanks
              • toufik sat
                • Feb 2016
                • 136
                • los angles
                Re: Hp g72
                thanks
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • badboyzzz
                  A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                  by badboyzzz
                  I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                  12-28-2024, 02:11 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • Neddsme
                  Bios partially corrupted somehow and now warm boot doesn't work which is critical
                  by Neddsme
                  Hie.
                  I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                  Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                  I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                  I managed to run Windows troubleshooting and...
                  02-04-2022, 05:57 AM
