Pls help. don't get the chance to meassure....
  • hansie55
    • Dec 2013
    • 254
    • Netherlands
    When I switch the laptop on, the led's light up for a brief moment and everything is out again. The battery charges and that led lights up after a few seconds.
    I don't get the chance to meassure anything and don't know where to start.
    Can somebody pls advise how to attack this problem?
    Dell Vostro 3360
    mobo: DA0V07MBAD1
  • khaahk
    • Dec 2013
    • 815
    • Estonia
    Re: Pls help. don't get the chance to meassure....
    Measure resistances on big coils.
    • hansie55
      • Dec 2013
      • 254
      • Netherlands
      Thanks for the reply.
      PL1=2,1 PL5=2,0 PL9=2,1
      PL2=3,2 PL6=1,8
      PL3=2,8 PL7=0,8
      PL4=2,6 PL8=0,8
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        for me could be chipset that need to be reballed. (not reflown)
        does fan spin ?
        if it doesnt spin could be also a cpu voltage problem.
        • hansie55
          • Dec 2013
          • 254
          • Netherlands
          Reball is not possible.
          Fan does not spin
          Where do I look for cpu voltages?
          • khaahk
            • Dec 2013
            • 815
            • Estonia
            Measure resistances relative to ground, not across coils.
            • hansie55
              • Dec 2013
              • 254
              • Netherlands
              Sorry.
              PL1=400
              PL2=12,5
              PL3=3,1
              PL4=12,2
              PL5=45k
              PL6=92
              PL7=1,8
              PL8=490
              PL9=1,5M
              • khaahk
                • Dec 2013
                • 815
                • Estonia
                PL3 and PL7 seem low, what are they powering? If you have schematic then post it.
                • hansie55
                  • Dec 2013
                  • 254
                  • Netherlands
                  Both 0.0V
                  something bad just happened. While measuring the V from PU7, I accidentally touched PC136 (gnd side) while measuring pin 10 (little smoke signal)
                  All the pins were giving a reading, now not anymore.for example, pin 7 was 3,3v is now 1,4v so I think I have to replace PU7 first?
                  • khaahk
                    • Dec 2013
                    • 815
                    • Estonia
                    Probably yes, you'll have to change PU7.
                    Remove cpu and remeasure PL3 and PL7 resistance.
                    • hansie55
                      • Dec 2013
                      • 254
                      • Netherlands
                      Sorry for the late reply. I'm still fighting to replace PU7. I got it off OK, but I can't get it in place and now my solder-station break so I have to order that first.
                      Let you know when things pick up again.
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1490
                        • portugal
                        hi there , you wont have voltages on coil , only after s5 , the only coils you might have power and the ones for the main reg and the bat coil .
                        first things you must measure , chek on off button , if you got 3.3 volts and if it drop to 0 once you press the button , if you got no voltage , chek the KBC pin first to see if you got or not the 3.3 volts , if not than you must chek main regulator , chek if you got correct LDO and EN pins .
                        cheking the values you mentioned on the coil to the GND there is none showing short , and possible the LOW ohm are the coils for the cpu .. it the cpu is one of does that you can remove frmo board , remove cpu and read coils again you must have a bigger value without cpu .
                        pu7 is dead now , but DONT TURN IT ON WITHOUT PU7 or else you will burn a few mosfets , and might kill some outher parts .. so if you want to make test to the board without PU7 , remove the mosfet associated to that IC .
                        once you remove PU7 and the mosfet , for that IC chek COILS to GND first , before adding a new PU7 , to make sure you dont have anything damaged on that line /lines .
                        if all good of what i mentioned , start for cheking S3 states . common signal on KBC .
                        also once you turn it on , chek usually on the main QFN if you got PGood signal received , if not , then its time for a KBC chek , chek all VCC and all S3 S5 pins , specially make sure RSMRST , workes fine , once you press the on off button , it its not working properly then KBC will order to shutdown machine .
                        make measurements before adding new components hansie , and let us know
                        • hansie55
                          • Dec 2013
                          • 254
                          • Netherlands
                          Thx Highpulse.
                          So I have to try to measure without the P7 ? (after removing mosfets).
                          The CPU can not be removed on this laptop.
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1490
                            • portugal
                            removing ONLY the mosfet that are drived from PU7 , after removing pu7 chek the coils
                            , so if cpu cannot be removed , i know you cannot reball so therefore also you cannot lift it .but for the values you give , doesn't seem cpu issue . but make the test i told you before going further with this
                            • hansie55
                              • Dec 2013
                              • 254
                              • Netherlands
                              Thx Highpulse.
                              Something I have to explain. I'm a senior on a amature level with years of experience in computer spare part business. I do have electronic training but I can't class with you guys at all. So I apologize for misconceptions on my behave.
                              I will follow your leads to the best I can but somethings might be to difficult. Like removing the 4 mosfets belonging to PU7. This is very hard for me, because I have Parkinson Illness and smd is very tiny. I have broken a couple of motherboards in the past already trying to replace chips. Parkinson and smd are no friends. Therefor it will be better for me to place a PU7 as that is difficult enough without damaging the rest.
                              It is not because I want to know better, but just because I can't.
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1490
                                • portugal
                                yeah i totally understand , and i respect you for that , you can be hill , but your fighting to keep live rooling , and that the spirit we are here to help
                                • dj_ricoh
                                  • 2073
                                  • uk
                                  Hansie55 you need to make some jigs on hot air and that will be your best friend.
                                  jig for hot air element and it needs to be a little tall so you can put a pre-heater under it.
                                  i`m making one now and next month i`m buying a pre-heater.
                                  and when it comes to QFN soldering yes you need hot air and soldering iron to finish the solder on the side.
                                  • hansie55
                                    • Dec 2013
                                    • 254
                                    • Netherlands
                                    Thx Guys,
                                    I will buy a hot air unit end of this month. I tried with a hot-air gun (for paint),but that can not be controlled and you loose a lot of tracks on the mobo.
                                    When I have it, I will consult you for the use.
                                    thx for understanding
                                    • dj_ricoh
                                      • 2073
                                      • uk
                                      Originally posted by hansie55
                                      Thx Guys,
                                      yes!
                                      so if the hot air station got level from 1-8 on air level; on the mobo you use max 2 and MAX 400c (380c )
                                      • ktmmotocross
                                        Boardkiller
                                        • Feb 2014
                                        • 3627
                                        • slovakia
                                        Thx Guys,
                                        u can use pwm regulator to put down temp an air velocity on that paint gun.
