Hp 15 with a i5-10210u procesor reaches 95 grados C. Is there any chance to undervolt,?
  • dreico33
    • May 2018
    • 36
    • Bolivia
    Hellow guys,
    I have an Hp 15 i5 10210u with heat issues even after a complete cleanup on its collling assy. So i dont know of there isn any chance to undervolt ( and how )it in order to drop down its temp.
    Thank you for your time.
  • pc_okay
    • May 2022
    • 244
    • FRANCE
    I don’t think undervolting is a solution.
    When do you get this temp?
    Idle? burn ? full burn With gpu?
    Is the cpu throttling? Laptoop shutting down?
    Please Check the radiator (thermal assembly) all along, it must be really really hot all along.
    If the end Of the segment is not that hot, you might change it. (The radiator is broken, bend somewhere)
    If the part Of the radiator just top Of the cpu is not really hot , Check thermal grease, Check the scews.
    If radiator is really hot and the fan is spining fast, Check the tape between radiator and fan, if this tape is missing, fan willl not be efficient. (Check the picture)
    good luck!
    • dreico33
      • May 2018
      • 36
      • Bolivia
      Thank you fot your responce. I am getting anything between 75-99 Degrees C, just for normal user, (Office, Browsing , Windows Update Etc), and yes i have cpu throttling at some point. The weird thing is i get that temp 15 20 30 min or even more after i turn on the laptop.
      For example the laptop its on for about 10 min now and the temps are stable at 42 , 43 degrees C ( idle). The radiator while i was cleaning it i noticed discoloration on it.Also when i connect the charger temp goes higher.
      • pc_okay
        • May 2022
        • 244
        • FRANCE
        Laptop maybe in energy saving on battery.
        Is the fan spinning faster when cpu is hot ? Do you feel the hot air flow behind the laptop or where the air goes out?
        Check for greedy process in task manager, maybe something is using cpu in background.
        • evilgenius31
          Zephyrus G14 GA401QH-211 reaches bios but has no serial number and can't detect NVME drives
          by evilgenius31
          Hi Everyone -
          I'm working on a Zephyrus G14 GA401QH-211. I bought it on ebay, knowing it only boots to the bios. The serial number is missing when I enter the bios. I've also attempted to use multiple NVME SSDs, but the bios can't detect them.
          Does this seem like a software issue, or a hardware issue with the nvme slot / pcie controller?
          Thanks!
          11-08-2025, 07:17 AM
        • Edoardo Bardi
          HP 800 G3 brick no chance?
          by Edoardo Bardi
          Hi all guys
          i own a HP Elitedesk 800G3. The machine got bios totally bricked/erased and is not possible to recover any data/dump. the computer turns on electrically but obviously does not boot. I've done many research and bought the usb programmer CH341A. managed to find some dumps here and there online, correctly flashed, but noone works. I would like to ask:
          1. if is technically possible to boot up again the machine by not owning any more the data from the old bios (i still have the serial and the data printed on mainboard/chassis)
          2. why i found different...
          02-08-2024, 03:08 AM
        • ArchangelGabriel
          Need schematics and boardview for laptop with TigerLake procesor and PCH!
          by ArchangelGabriel
          Hello, în search of troubleshooting this laptop Gigabyte Aorus 17G YD! Mainboard GA-RX7GYD Rev 1.1! I need schematics from laptops with TigerLake processor and PCH, particularly SRKMA cip! Please!
          12-04-2023, 05:36 AM
        • dlhxr
          Any chance to extract my y540 bios dmi info from corrupted bios backup?
          by dlhxr
          Hi, I am a Legion Y540 user and I bricked my laptop downgrading from 41ww bios to 26ww, which was definitely Lenovo's fault.
          But I bought a ch3341a programmer. After backing up the corrupted bios, I flashed the stock bios successfully, but it turned out many motherboard variables are missing.
          Then I found a tool called LVAR by lenovo and wrote most of the dmi variables back refering to my original box and labels on my laptop, including product name, mtm number, sn, etc..
          But for other variables, it's really hard to know the original value.
          Is...
          04-13-2021, 09:28 PM
        • Grouickman
          Hofmann geodyna 6300 Wheel balancer
          by Grouickman
          Hi there,
          First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
          Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
          I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
          I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
          03-31-2025, 05:29 AM
