HP 800 G3 brick no chance?
  • Edoardo Bardi
    • Italy
    Hi all guys
    i own a HP Elitedesk 800G3. The machine got bios totally bricked/erased and is not possible to recover any data/dump. the computer turns on electrically but obviously does not boot. I've done many research and bought the usb programmer CH341A. managed to find some dumps here and there online, correctly flashed, but noone works. I would like to ask:
    1. if is technically possible to boot up again the machine by not owning any more the data from the old bios (i still have the serial and the data printed on mainboard/chassis)
    2. why i found different romset dumps, some only 16mb, others 8+16mb. so far i only tried to rewrite 16mb ones over the bios chip
    TY so much if someone can help
  • spleenharvester
    GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
    by spleenharvester
    I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
    07-08-2025, 06:02 PM
  • UADmytro
    Lenovo T14 Gen1 i7 10  nm-C931 (brick)
    by UADmytro
    Hey! I bought a Lenovo T14 Gen1 i7 10 nm-C931 (a brick). The previous owner said he got it on eBay as a password-locked device and took it to a repair service, where they tried flashing something. The result: it doesn't turn on.
    When I plug in the charger, the charging LED lights up, and the power button indicator blinks three times.
    I downloaded the firmware from the official website, but it's incomplete. However, there is a firmware for the embedded controller (MEC1663). I did a mass erase via OpenOCD, wiped MEC1663 along with the EEPROM, and flashed an image from the...
    03-23-2025, 03:45 AM
    HP Clean VSS2 dumps,fix Endpoint Security error
    by SMDFlea
    Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
    the infamous **"Endpoint Security" error message.
    Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
    I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
    The offsets and file sizes are part of the naming convention i`ve used for the extracted
    files.
    hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
    filling everything after...
    08-08-2024, 03:14 PM
  • 530v8
    Read out HP 650 G5 16MB Chip
    by 530v8
    Hi
    i have some problems reading out the 16mb chip on Keyboard Side.
    The 32MB Chip memory side i can read out but for unlocking i need the 16mb chip for the G5 series right?
    I use the Revelprog IS and WSON 8 6x8 Pins.
    Photo attached.
    Any idea?
    tried with ac adapter and without also with VPP 3V and disabled...
    11-08-2023, 01:25 PM
  • James Jackson
    Panasonic CF-20G0247VM BIOS Bad Flash Help
    by James Jackson
    I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
    Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
    05-01-2025, 11:28 AM
