Fujitsu AH512 No backlight
  • liamoc74
    • Feb 2015
    • 80
    • Ireland
    I have a fujitsu AH512 with a broken screen, when i took it in it had backlight but screen was cracked - routine job so I ordered screen and replaced, put back together and no backlight, checked old screen again and no backlight either!
    Has a fuse blown.??
    Ive done some looking and the AH530 has an F4 fuse that causes backlight failure - is this the same on the AH512.?
    Ive stripped it completly at this stage and looking around where the LCD connects to the board, i cant see anything labelled F4.?
    Anyone had similar prob or know where i start solving this one..?
    Cheers
  • liamoc74
    • Feb 2015
    • 80
    • Ireland
    Re: Fujitsu AH512 No backlight
    Can anyone help me out with this one..?
    • khaahk
      • Dec 2013
      • 812
      • Estonia
      Post good macro shot around connector from both sides of mainboard. F4 it should be.
      • trebo
        • 514
        • Wales, UK
        Cheers
        As you have a different board, It may not be F4, It could be any number with the F in front as in F101 or F2, or even may come like this, PF101
        But there is nearly always the F, can you post a picture of the Area around the lcd connector
        BTW this failure usually happens when you leave the battery connected when you change the screen
        • liamoc74
          • Feb 2015
          • 80
          • Ireland
          Yeah found it and got it sorted..
          Yeah i guess i just rushed it a bit -lesson learned
          • tazMe
            • Dec 2015
            • Israel
            Hi liamoc74,
            I have AH532 and dont see the fuses anywere,
            Can you please tell me Where did you found them ?
            10x
            • HTR-Informatique
              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
              by HTR-Informatique
              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
              I also changed the screen because the PC fell and the screen was broken.
              I changed the battery with a new and original battery.
              I also had corrosion/oxidation on the...
              02-09-2025, 06:51 AM
            • frannyjunk
              Hisense 40H4F no backlight but turns off after splash screen
              by frannyjunk
              So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
              TIA.
              09-24-2025, 10:59 AM
            • turmix
              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
              by turmix
              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
              During another reassembly, I made a mistake, and...
              01-29-2024, 03:48 AM
            • FallenOne008
              Asus G712L No Screen Backlight
              by FallenOne008
              Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
              The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
              03-31-2025, 08:27 PM
            • trepachka
              HP Probook 450 G8 Boardview+Schematics - screen backlight issue
              by trepachka
              I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
              Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
              Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
              03-16-2024, 12:32 AM
