need novuton npce 885 pa0dx pinnot data sheet
  • HarryPK
    • Mar 2014
    • 212
    • barabai
    I need novuton npce 885 pa0dx pinnot data sheet.
    Anyone helped very appriciete. Thank for any help. I' m sorry for bad in english
  • HarryPK
    • Mar 2014
    • 212
    • barabai
    Re: need novuton npce 885 pa0dx pinnot data sheet
    Up.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      laptop merk apa? Model?
      Kupikir bila mempunyai skemanya maka akan lebih mudah.
      What brand of laptop? Model? I think if the scheme had it will be easier.
      • dj_ricoh
        • 2073
        • uk
        OK!
        i found that KBC in a Acer Aspire v5-531 and 571
        page 27
        check it out!
        • HarryPK
          • Mar 2014
          • 212
          • barabai
          Acer aspire v5 -132
          Thanks for advanced
          • HarryPK
            • Mar 2014
            • 212
            • barabai
            Originally posted by dj_ricoh
            OK!
            page 27
            check it out!
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              schema:
              • HarryPK
                • Mar 2014
                • 212
                • barabai
                Originally posted by meritosari
                schema:
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • welcometoo
                  acer nitro 5 AN515-55 no display / caps lock
                  by welcometoo
                  Hi brothers, please i need help diagnose acer nitro 5 no display issue.
                  model: nitro 5 an515-55
                  motherboard part number: GH51M LA-K862P Rev: 1A
                  i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
                  i flashed new bios also ec(ene kb9022) the same result .
                  disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
                  07-05-2025, 11:11 AM
                • kingiii
                  Possbility of data recovery, is it true?
                  by kingiii
                  Hello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not...
                  07-02-2025, 02:29 PM
                • flibidy
                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                  by flibidy
                  I have here a Magnum IA.100 which belongs to my parents.
                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                  What Ive done........
                  01-01-2025, 01:26 PM
                • mscottdoran@gmail.com
                  Can anyone identify the classification of this data signal?
                  by mscottdoran@gmail.com
                  Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                  The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                  The boards are powered by a ground referenced...
                  02-08-2025, 11:31 AM
