Does anybody known the equivalent BIOS EC CHIP of WINBOND W25x010BVSNIG ?
WINBOND W25x010 equivalent ??
Re: WINBOND W25x010 equivalent ??
somewhere i found this
SOIC8 interchangeability chips
32 Mbits (these chips are equivalent and interchangeable)
A25L032M-F AMIC
AMIC A25L032M-UF
MX25L3205DM2 Macronix
EN25F32-100H EON
W25X32VS WINBOND
WINBOND W25Q32VS
SST25VF032B SST
16 Mbits (these chips are equivalent and interchangeable)
A25L016M-F AMIC
AMIC A25L016M-UF
MX25L1605DM2 Macronix
EN25F16-75H EON
EON EN25F16-100H
-75H EN25D16 EON
EON EN25D16-100H
W25X16VS WINBOND
WINBOND W25Q16VS
SST25VF016B SST
8 Mbits (these chips are equivalent and interchangeable)
A25L080M-F AMIC
AMIC A25L080M-UF
MX25L8005M2 Macronix
EN25F80-75H EON
EON EN25F80-100H
W25X80VS WINBOND
F25L008A-50PA ESMT
ESMT F25L008A-100Pa
SST25VF080B SST
4 Mbits (these chips are equivalent and interchangeable)
A25L040M-F AMIC
AMIC A25L040M-UF
MX25L4005AM2 Macronix
EN25F40-75H EON
EON EN25F40-100H
W25X40VS WINBOND
F25L004A-50PA ESMT
ESMT F25L004A-100Pa
SST25VF040B SSTComment
I wonder what is better reprogram the old one, of change it with a new one, what do you guys thinkThe Night Drop Down, I Will Keep Try Until..., You Never know.
Dushi Kòrsou, Nos Tei.Comment
Just want to share some observations I have made. Sometimes it also depends on the schematics. I have seen some schematics that may support maybe 2, 3 or all brands . Toshiba models most of the time support only Winbond chips. I remember some time back I programmed a Macronix chip for a Toshiba board (LA-6832P) because the Winbond chip on it was corrupted and the board never booted. I had to look for a Winbond replacement and that worked. So You have to look for the schematic of the board you are working on and check to see if it supports alternative chips. Some examples below.. Quanta QT8 schematic showing SPIs the board support and an HP Envy TouchSmart 15 [15SBGU-6050A2547701-MB-A02] that had a corrupted Winbond chip and I was trying to replace with an EON chip (pc never booted). So the long and short of it is that the board has to support the replacement...
I hope someone can help me.
I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
A valid BIOS/EC backup...-
Channel: BIOS Requests ONLY!
by Max74747Hello everyone,
I’m looking for a verified BIOS dump for a Beelink Gemini M mini-PC.
The device is now bricked after flashing the official BIOS file from Beelink’s website (M41N100_1018_GeminiM8G36.bin).
Details:
Model: Gemini M-H-8128QD0W64PRO
CPU: Intel Celeron J4125 (Gemini Lake Refresh)
Serial number: 4125HOLH70514
BIOS chip: Winbond 25Q128FW (8-pin SPI, 3.3 V)
Symptom: Power LED and fan run, but no HDMI output after flash.
If anyone has a working dump (.bin) for this revision,...-
by Boris242Is it possible to read this cip winbond 25q256jvfq with EZP2019+ reader to remove forgotten bios password?
thanks Boris-
I’m working on a Dell PowerEdge R340 (Service Tag: JTMLKB2).
The iDRAC is bricked — system hangs at “iDRAC initializing,” fans at 100%, and no VGA output.
The cause is a bad firmware flash to the iDRAC SPI.
Board details:
- Model: Dell PowerEdge R340 (14G)
- iDRAC version: iDRAC9
- Flash chip: Winbond 25Q032 (32 Mbit / 4 MB)
- Tool used: CH341A programmer
What I need:
- A clean, working 4 MB `.bin` dump of the 25Q032 from another R340...-
by TechMark1I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted.
I just zipped it so I could attach it....
- Loading...
