WINBOND W25x010 equivalent ??
  • tata123
    • Nov 2013
    • 104
    Does anybody known the equivalent BIOS EC CHIP of WINBOND W25x010BVSNIG ?
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: WINBOND W25x010 equivalent ??
    Almost all other manufacturers have compatible devices, just make sure the
    25x010 is the same.
    • tata123
      • Nov 2013
      • 104
      for example? could it be MX or other firms? or should it be Winbond?
      – W25X10A: 1M-bit / 128K-byte (131,072)
      • tibd
        • Oct 2014
        • 189
        • Sweden
        it could be other firms but the code must be same as you mentioned
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          no need to have same code ,
          alltough after the X usually they must have same number , 10 = 128K
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            somewhere i found this
            SOIC8 interchangeability chips
            32 Mbits (these chips are equivalent and interchangeable)
            A25L032M-F AMIC
            AMIC A25L032M-UF
            MX25L3205DM2 Macronix
            EN25F32-100H EON
            W25X32VS WINBOND
            WINBOND W25Q32VS
            SST25VF032B SST
            16 Mbits (these chips are equivalent and interchangeable)
            A25L016M-F AMIC
            AMIC A25L016M-UF
            MX25L1605DM2 Macronix
            EN25F16-75H EON
            EON EN25F16-100H
            -75H EN25D16 EON
            EON EN25D16-100H
            W25X16VS WINBOND
            WINBOND W25Q16VS
            SST25VF016B SST
            8 Mbits (these chips are equivalent and interchangeable)
            A25L080M-F AMIC
            AMIC A25L080M-UF
            MX25L8005M2 Macronix
            EN25F80-75H EON
            EON EN25F80-100H
            W25X80VS WINBOND
            F25L008A-50PA ESMT
            ESMT F25L008A-100Pa
            SST25VF080B SST
            4 Mbits (these chips are equivalent and interchangeable)
            A25L040M-F AMIC
            AMIC A25L040M-UF
            MX25L4005AM2 Macronix
            EN25F40-75H EON
            EON EN25F40-100H
            W25X40VS WINBOND
            F25L004A-50PA ESMT
            ESMT F25L004A-100Pa
            SST25VF040B SST
            • Life Goes On
              • May 2014
              • 264
              • Curacao
              I wonder what is better reprogram the old one, of change it with a new one, what do you guys think
              The Night Drop Down, I Will Keep Try Until..., You Never know.
              Dushi Kòrsou, Nos Tei.
              • tata123
                • Nov 2013
                • 104
                If the BIOS CHIP is not broken, its the same, this is a only a BIOS CHIP.
                @ktmmotocross thank you for the list
                • siddiq
                  • Dec 2011
                  • 121
                  • Ghana
                  Just want to share some observations I have made. Sometimes it also depends on the schematics. I have seen some schematics that may support maybe 2, 3 or all brands . Toshiba models most of the time support only Winbond chips. I remember some time back I programmed a Macronix chip for a Toshiba board (LA-6832P) because the Winbond chip on it was corrupted and the board never booted. I had to look for a Winbond replacement and that worked. So You have to look for the schematic of the board you are working on and check to see if it supports alternative chips. Some examples below.. Quanta QT8 schematic showing SPIs the board support and an HP Envy TouchSmart 15 [15SBGU-6050A2547701-MB-A02] that had a corrupted Winbond chip and I was trying to replace with an EON chip (pc never booted). So the long and short of it is that the board has to support the replacement...
                  • Vincent Kahle
                    Winbond 25Q16JWNIG – Asus ROG Strix Scar 18 G814JZ bricked after wrong flash – Need help
                    by Vincent Kahle
                    I hope someone can help me.
                    I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
                    Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
                    I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
                    A valid BIOS/EC backup...
                    06-05-2025, 09:27 PM
                  • Max74747
                    Request: Beelink Gemini M BIOS dump (SN 4125HOLH70514 – Winbond 25Q128FW)
                    by Max74747
                    I’m looking for a verified BIOS dump for a Beelink Gemini M mini-PC.
                    The device is now bricked after flashing the official BIOS file from Beelink’s website (M41N100_1018_GeminiM8G36.bin).
                    Details:
                    Model: Gemini M-H-8128QD0W64PRO
                    CPU: Intel Celeron J4125 (Gemini Lake Refresh)
                    Serial number: 4125HOLH70514
                    BIOS chip: Winbond 25Q128FW (8-pin SPI, 3.3 V)
                    Symptom: Power LED and fan run, but no HDMI output after flash.
                    If anyone has a working dump (.bin) for this revision,...
                    10-18-2025, 12:25 AM
                  • Boris242
                    winbond 25q256jvfq
                    by Boris242
                    Is it possible to read this cip winbond 25q256jvfq with EZP2019+ reader to remove forgotten bios password?
                    thanks Boris
                    10-16-2025, 08:10 AM
                  • maximus-bullitt
                    Request: Dell PowerEdge R340 iDRAC9 SPI dump (Winbond 25Q032)
                    by maximus-bullitt
                    I’m working on a Dell PowerEdge R340 (Service Tag: JTMLKB2).
                    The iDRAC is bricked — system hangs at “iDRAC initializing,” fans at 100%, and no VGA output.
                    The cause is a bad firmware flash to the iDRAC SPI.
                    Board details:
                    - Model: Dell PowerEdge R340 (14G)
                    - iDRAC version: iDRAC9
                    - Flash chip: Winbond 25Q032 (32 Mbit / 4 MB)
                    - Tool used: CH341A programmer
                    What I need:
                    - A clean, working 4 MB `.bin` dump of the 25Q032 from another R340...
                    09-28-2025, 04:22 PM
                  • TechMark1
                    Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
                    by TechMark1
                    I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
                    09-21-2025, 03:36 PM
